head chamber
head chamber
im trying to work out my compression. could you please tell me the head chamber size in cc's and the head gasket thickness.
but have you measured it when head bolts are torque'd?
i'll double check on my TT, as i need to strip the engine down over the weekend, and measure it before i take the head off.
thankyou for the information guys. If i use the details fiescos dan has give me then i have a compression of 7.7:1
The engine is standeard rs turbo with an overbore. now is this too low?
i have had engine failure due to std rod bolts faling , so now use ARP's only
std cc on the head is around 56cc unskimmed , and about 5cc for the headgasket , its the numbers i have used
std rods can be polished for extra safety
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
