Getting Engine Back
Old Nov 14, 2007 | 07:21 PM
Moose's Avatar
Moose
Default Getting Engine Back
After a two and a half month wait im finally getting my engine back, im just curious to wether it will be ok to run it in on the re map stu did on the standard ecu, the spec of the engine is:
ported big valve head
matched manifold
piper fast road cam
0.5 over bore
new standard compression pistons
(pistons balnced)
balanced and polished con rods
knife edge crank
lightened flywheel
all crank-flywheel-clutch-front pully were balanced together
all arp bolts in bottom end
will be using millers running in oil
will be using standard T3 turbo and a pro alloy front mount cooler.
will i have to get it re-mapped and chipped straight away or will i be able to run it in like this till the engine is bedded in, i dont fancy it running lean or rich and knackering it
cheers for any advice Rich
Old Nov 14, 2007 | 09:19 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
what engine is it...zetec, cvh, zvh, YB or something else
was the ecu mapped for that engine spec or another ?
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
ekjim
Aug 17, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
