next mod ???
right then,had the escort on RR lst week and made a very diaspointing 116bhp ATW
was kind off hoping for more,has following mods
full width intercooler,
s/s exhaust,
chipped ecu,
leads
n that bought it,when it was on th rollers they wer unsure if it has a cam,i no for defo it has no pully as had t cover of few weeks ago but not had chance to hav a look at th cam yet,
anyways,hwat my best mod next,was thinking of new actuator but was then thinking i may buy new turbo,t3 stage 3 hybrid
what you all think ?
s/s exhaust,
chipped ecu,
leads
I'd get it set up properly first and replace the almost certainly soggy actuator if it's more than a few years old.
imho a Stage3 hybrid turbo will be too much for the rest of your spec. Once you are sure the car is running well I would look at fitting an uprated cam and see where that leaves you.
cheers mate
when i 1st went up it was only 106 atw then they fitted a bleedvalve ?(not sure bout this)
then used that to up th boost it used to boot to .5 before now it peaks at .9 then drops to around .75
you think my acutators total shagged or maybe a fuked turbo ?
1st turbo ive ever owned you see so bear with me haha
sean
sean
Originally Posted by Dragsteer
116 at wheels means +35 on flywheel? If I am right, standard RST has about 35 bhp looses at gearbox and others stuff.
sean
sean
so why is my car so sh*t haha ?????
all they sed was its overfueling and hardly boosting
how come on ebay almost every rst for sale says 180bhp form a chip haha
Your car is making no where near the power it should with the mods you have, sort the fueling and the boost out then you will see an increase in power
I don't think its massively out. 0.75 bar of boost is only 11psi, thats only 4psi more than standard. It only takes for it to be overfuelling a little and that would cost it the 10-15bhp that I think it may have lost. The cooler will only make a significant difference at higher boost, the standard cooler can cool 9-10psi reasonably well.
If the turbo is in good condition, knowing that it has a full-width cooler, it could run 16 or maybe even 18psi. Even then, I'd only expect around 140bhp ATW or so.
SMILER258
Sep 28, 2015 09:04 AM
