chipped ecu? help
have u got a boost gauge? if so and it boosts over 10psi without the engine cutting out then its chipped, if u dont have a boost gauge remove the ecu unscrew the back then unscrew the board and turn it over and u should see a long chip in the middle most tuners put a sticker on it if its a aftermarket chip ie white dot with a blue s for superchips, or a sticker saying turbosystems etc... a std chip is a normally a motorolla one
