sperical strut top mounts ,
Originally Posted by beefy-rst-2
some ive seen look just like the strut tops been cut down and a steel ring with a lip, has been welded in , then the mount is just bolts onto that ?
the hard part is getting them in the right place i would have thought
Ive fitted Mk1 escort eccentric top mounts with spherical bearings to my early Mk3 2 bolt shell...
Took a lot of measuring and head scratching, but its possible.
Dont have any pics i'm afraid
any more info stu ?
and them top rings look a lil fat aint they ?
in the sense of where the mount sits ?
i can get the turrets fabbed up locally by a gud mate ,
its more the positioning and do the then need strengthing to the underside of the inner wing ?
seeing as were talking about it ,
are the rears feesable ?
Designed to fit up the standard late Mk3 / Mk4 turrets so minimum mods required. (2 fixing holes)
Ideal for cars running adjustable TCA's, helps to guarantee strut top castor/camber setting on fast road/track cars.
Alloy construction with replacable race spec bearing
We have the type you pictured in stock, but they will require extensive turret mods to the car as per Stuarts car (flat topped towers).
The ones I pictured require NO turret mods, but wont fit your car as they are not designed for the early Mk3.
They fit straight onto all late Mk3 and all Mk4 cars as stated
Originally Posted by smitsturbo
will the above ones fit on to a pre 83 escort??
as yours must have them top mounts as your in a 16i??
or what about these ones
its RATBOY off of here
Originally Posted by Christian and Beccy
That is one mother-fucking huuuuuuuuge turbo. Will certainly be impressive, if its on boost before the rev limiter!!
Looks AWESOME though.
he seems to have all the bases loaded on the spec list
gonna have to pop round soon dude and have a peek
When you alter bottom geometery angles with things like adjustable tca's etc, your normally pushing against a rubber top mount up in the turret. Rubbers natural tendancy is to push back potentially putting the suspension under some strange loads during hard use/cornering. These have a bearing up at the top instead of rubber so you can guarantee that what you want is what you get all the time
Any clearer ?
Any clearer ?
03-11-2015 04:08 PM
