Diesel gearbox
Diesel gearbox
Hello mates,
is there a option using a dieselgearbox when you're running too much bhp for the std one? can these gearboxes handel more torq? and can i buildt the sperdiff from the std into a diesel or do i have too buy a upgraded box?
Hope someone can tell!
Despite the bullshit that's been bandies about pubs for many years teh diesel gearbox is no tougher than the standard item. Get in contact with Competition Gearbox Services. Bernies boxes are tough as nails, certainly survived what my brother and I have thrown at ours.
www.gearboxman.co.uk
As Oranoco said the diesel box is NO stronger than the standard item!!!
What power is your car running?
My car is 230 bhp and running a standard box!
i havent had any problems because i dont do hard launches which is when they tend to break!!
cheers
For ALS you will need to swap the management over to at least Cossie (and I seem to recall only some ECU's will support the ALS and require an additional board). You will also need a modified throttle body and valve and a Maram 247 shafted turbo to stop the heat generated killing things off.
If you have to ask about the price of it then you can't afford it.
ok! tnx mate. i'll forget about that then! and i'll also forget about the dieselgearbox and just going to try running the std gearbox!
chowfornow
14
05-01-2019 09:01 PM
