do efi escort looms disconnect like fiesta turbo looms?
Old 11-11-2007 | 08:15 PM
rst in breaking's Avatar
rst in breaking
Default do efi escort looms disconnect like fiesta turbo looms?
i need a efi escort engine loom but someone said they come as a complete loom, car loom inc? cheers
Old 11-11-2007 | 10:21 PM
rst in breaking
anyone?
Old 11-11-2007 | 10:26 PM
xr4x4rs's Avatar
xr4x4rs
no its all built in 1 loom mate
Old 12-11-2007 | 04:58 PM
rst in breaking
oh bugger, is it as easy to wire into an escort as a fiesta loom if i cut engine loom out as im guessing it only has a few wires?
Old 12-11-2007 | 05:00 PM
lardypants's Avatar
lardypants
i thought they had a couple big plugs near bulk head right side of manifold?
Old 12-11-2007 | 05:01 PM
rst in breaking
thats what i was unsure of as a fiesta loom does, does a mk5 cvh efi loom unplug if not?
Old 12-11-2007 | 05:02 PM
lardypants's Avatar
lardypants
i changed an engine on a 16v efi last week and that had them
Old 12-11-2007 | 05:03 PM
rst in breaking
i thought the 16 would but think i need an 8v loom for zetec turbo or am i wrong? cheers
Old 12-11-2007 | 05:06 PM
Šhatter Box's Avatar
Šhatter Box
mk4 efi all one loom
mk5 efi 2 part loom
Old 12-11-2007 | 05:07 PM
rst in breaking
so if i get mk5 cvh efi is that 2 part?
Old 12-11-2007 | 05:11 PM
danny_boy699's Avatar
danny_boy699
chatter 4 life
i got a mk4 efi 1 that plugs near the in let and in other places like a zetec 1
Old 12-11-2007 | 05:26 PM
rst in breaking
i need one!!! lol
Old 12-11-2007 | 06:47 PM
xr4x4rs's Avatar
xr4x4rs
rst in progress
you just want the injector loom then?
as this is all that plugs up on a mk4 efi
the ecu plug etc are built into main loom
fiesta engine loom, is seperate from car loom, but injector loom is the same as mk4 efi
Old 12-11-2007 | 08:52 PM
rst in breaking
Originally Posted by xr4x4rs
rst in progress
want an entire engine loom like fiesta but looks asthough il have to extend my loom. ive had mixed feedback as to weva a mk5 loom disconnects?
Old 12-11-2007 | 10:25 PM
S1's Avatar
S1
I stripped an Efi escort today for the loom as i want to convert my ERST to Efi. The internal loom is all part of the engine bay loom as well. It joins to the injector/sensor loom in the sam way that an FRST engine loom joins. The interior/engine bay loom needs a couple of connectors moving on the ecu, then you can just plug the FRST ecu to the escort interior loom.
Old 12-11-2007 | 10:36 PM
rst in breaking
so just have to pin out a couple of wire, i.e lives etc and can wire it in?
Old 12-11-2007 | 10:42 PM
S1's Avatar
S1
Yeah, pretty much, think there is a how to somewhere, might be on Fiestaturbo.com. IIRC its the same wires need moving as if you were turboing an Xr2i, the efi escort uses the same ecu as the xr2i so that would make sense.
Old 12-11-2007 | 11:50 PM
xr4x4rs's Avatar
xr4x4rs
just about to say that
if you get a full efi loom for a mk4
fiesta ecu will plug straight up
now depending on which ecu u have, ofac or ofab
ofac uses the same style map sensor plug as std efi mk4
ofab uses a map sensor like a cossie
if you go ofab you need to wire in the connector for the map sensor and the supressor for the map sensor, these are only found in a fiesta ofab loom
other than that its just match tepins up from a escort to a fiesta
the one i converted a few years ago, didnt need any pins changing over, but some do
Vincereese
01-06-2023 10:14 AM
EoinXR3
07-09-2015 06:44 AM
Vincereese
16-08-2015 07:38 PM
muz
16-08-2015 01:57 PM
gingerturbo
11-08-2015 10:44 PM
Quick Reply: do efi escort looms disconnect like fiesta turbo looms?
