BAD RUNNING S2???
BAD RUNNING S2???
HI, IM ARFTER SOME ADVICE ON MY S2, WHEN STARTED FROM COLD IT STARTS FINE, ARFTER A FEW MINUTES, WHEN IT WARMS UP, IT DIES IF U KEEP IT REVED ITS OK BUT ANOYING AND IMBARISING WHEN IN TRAFFIC , IF U DO STALL IT AND TRY TO RESTART I WILL NOT START , NOT UNLESS U LEAVE IT FOR 5 MIN THEN STARTS BUT STILL TRIES TO DIE, IVE CHECKED FOR AIR LEAKS, BUT STILL NO HELP
CHEERS
CHEERS
The problem from the warm start is the starter, it gets overheated! it's a normal problem. just make a heathshield or buy one on ebay.
The other problem is maby that the revs for normale running are a bit low?
