AE pistons
Old 18-11-2007, 05:07 PM
juffer
juffer's Avatar
Default AE pistons
are they standard or are they a tuning part?
Old 18-11-2007, 05:11 PM
sm
sm's Avatar
pretty sure they are std pistons
Old 18-11-2007, 05:17 PM
juffer
juffer's Avatar
the reason i was asking was because i thought OE was standard.
Old 18-11-2007, 06:18 PM
Fiecos Dan
Fiecos Dan's Avatar
they are a pattern part piston.
but Tim ( Grey S2, nms RST) used them for over 300 bhp with out issue.
I built a RST engine last month using them, but the C/R did come out abit higher than std mahle's.
Old 18-11-2007, 06:24 PM
juffer
juffer's Avatar
thanks for that. i take it that standard rods fitted to these would be no good for about 18 psi.
Old 18-11-2007, 07:42 PM
Dragsteer
Dragsteer's Avatar
AE cam , is this cam good? I have offer for new AE cam , 50 pounds
Old 18-11-2007, 08:22 PM
sm
sm's Avatar
rods will be fine i used to run my rst at 18psi on std rods for 3 years with no probs the rods are at there max at about 230bhp
Old 18-11-2007, 08:35 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Mahle = OEM
AE = Pattern
OE = Original Equipment (see above).
Old 18-11-2007, 09:24 PM
juffer
juffer's Avatar
so basically a AE piston is the same as a standard item but an aftermarket make.
Old 18-11-2007, 09:26 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Yes.. AE are one, if the the biggest piston manufacturer in the world.
Old 19-11-2007, 11:24 AM
Dragsteer
Dragsteer's Avatar
So AE cams are standard cams? I mean standard to specifications
Old 19-11-2007, 03:51 PM
gee1599
gee1599's Avatar
AE pistons are made to OE spec
i have a set here and thats what is says on the box (but mine have been skimed)
Old 20-11-2007, 06:38 PM
davsmith64
davsmith64's Avatar
i broke my AE piston in 4 pieces between the piston rings..
Old 20-11-2007, 07:34 PM
Fiecos Dan
Fiecos Dan's Avatar
Why did it happen tho?
Old 20-11-2007, 08:09 PM
JamboRS
focus rs 1672
JamboRS's Avatar
prob same way it happened to mine, det
Old 20-11-2007, 08:45 PM
sm
sm's Avatar
same happened to me due to too much boost and not enough fuel
Fiecos Dan
Fiecos Dan's Avatar
Thats why i asked, as this problem might not be down ti any fault of the actual piston.
Old 21-11-2007, 03:07 PM
davsmith64
davsmith64's Avatar
when i took the piston to the machinists he rekoned it was because the car was running too much compression.. i was running 16 psi at 230bhp
Old 21-11-2007, 04:00 PM
Dragsteer
Dragsteer's Avatar
so boost kill him?
Old 22-11-2007, 04:56 PM
davsmith64
davsmith64's Avatar
i rekon so
Old 22-11-2007, 07:17 PM
juffer
juffer's Avatar
am i right in thinking that with a good healthy engine you can only run a maximum of 18 psi with these pistons and standard rods. a bigger front mount cooler and actuator are fitted.
Old 22-11-2007, 07:27 PM
Fiecos Dan
Fiecos Dan's Avatar
Your wrong,
As i said earlier in this thread, Tim used to run 300+bhp on these pistons.
And his car does 165+ mph, 12.7 1/4 miles, and often does trackdays.
Old 24-11-2007, 09:12 PM
rstdave
rstdave's Avatar
I'm still using them in mine, runnin 245bhp at 1.5 bar boost with no issues....just had the head off as it happens and there are no signs of wear. To be honest most melt downs are due to poor mapping/fuelling, mine's on omex and mapped correctly i don't think it's the pistons that cause any problems
Old 24-11-2007, 09:17 PM
Rick
Rick's Avatar
i'm running 1.7 bar on a totally std bottom end atm (sorry rich )
Old 24-11-2007, 09:52 PM
T28 RST
Ok then
T28 RST's Avatar
Was it standard compression Dave coz im running similar power and boost
As Jamie said it was probably down to detonation that your piston went bang
Old 24-11-2007, 10:52 PM
Rick
Rick's Avatar
compression pressure and boost are two different things
Old 25-11-2007, 11:52 AM
juffer
juffer's Avatar
i was getting my figures from a performance ford mag about 6 months ago when they did a veview on the cvh turbo. it says the crank is tough as old boots but the rods will give at 19 psi boost. why do they print this if it is not true?
Old 25-11-2007, 12:01 PM
Billy_RS
Billy_RS's Avatar
Old 25-11-2007, 12:12 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
.. because they're not engineers and rely on chinese whispers (or opinions from 'expert tuners')..
I know reputable tuners who run at least 1.5 bar on standard rods (with machined pistons).. with zero problems in the last 20 years.
Old 25-11-2007, 12:16 PM
Fiecos Dan
Fiecos Dan's Avatar
boost can not be related to stess on the engine unless they stat the turbo being used.
as a std T3 on 19 psi = 180bhp ish
19 psi on a T34 will be 250bhp ish, and so on.
Old 25-11-2007, 12:32 PM
juffer
juffer's Avatar
these figures were based on a standard engine with standard turbo. I was going to go down the route of mahle pistons but i cant see the point now.
Old 25-11-2007, 01:13 PM
Fiecos Dan
Fiecos Dan's Avatar
What was writin in the mag then was a very safe margin power range.
Old 25-11-2007, 01:22 PM
juffer
juffer's Avatar
it was just a break down of the engine. it basically siad that the head flows pretty well as standard, the pistons were ok for 20ish psi, rods ok for 19 psi. the flywheels are know to fly off. ect. it basically said that if your going over 1 bar you need to start uprating the engine.
01-11-2015 06:53 PM
little bram
04-10-2015 12:13 AM
deathrider666
28-09-2015 06:12 PM
timsrs
22
24-09-2015 08:14 PM
ajamesc
08-09-2015 06:51 PM
Quick Reply: AE pistons
