- ignition modul
- ESCORT ECU INTO A FIESTA??
- ST 170 CLOCKS INTO A ZETEC DIESEL
- alternator problem!
- acid dipping
- Camshaft a tad tight :s
- oil light UPDATE
- COSSIE BRAKES ON RST
- gearbox trouble
- 4x4 saff wobble
- Cossie runs for 10 secs then cuts out
- R1 throttle bodies help!
- Amal valve
- Lights On Dash problem
- timing/firing order
- Tuning beyond greens
- manifold glowing b/red
- compomotive fiting
- suspension
- battery light
- Samco Hosing
- bleed valve
- zetec flywheel
- starter motor
- Best Mk5 Escort
- changing exhaust manifold on escort mk6 1.6 efi
- Wires on amal valve
- car cuttin out
- power for guages and stereo??
- fiesta rs turbo overheating!!! :( help!!
- Mapping and weather conditions (temperature)?
- engine time
- warm relay please help!!!!!!!!!!!!
- ESCORT RS TURBO ANTI-ROLL BAR.
- ford fiesta 1999 mk4 stereo diagram
- is this carb or single point injection?
- Air bag Light
- ICV on Zetecs
- XR4x4 to rwd
- oil
- Borg Warner T-5 Transmission book
- ignition problems and questions
- map sensor
- Zetec 2.1 help needed!
- Mk5 RS 2000 Head Gasket Change
- Timing Chain or Belt ??? 2.0 Duratec HE engine
- LSD ratings (to rally boys and transmission experts)
- puma bearing gone tits
- funny noise from the engine bay
- Converting to a Turbo
- a f r on w.o.t on turbocharged engine
- escort cosworth fuel system
- 16inch under a fiestaturbo mk3???
- Installing an aftermarkter REVcounter???
- Clifford Concept 100.
- mk5 rs2000 light fault
- Misfire at high boost on cossie
- NO REV CLOCKS FOR CLOCKS WITH REV
- fuel pressure
- Loads! lol
- v6 on carbs?
- YB Rear Crank Seal Installing Tool
- Which tranmission oil?
- CHANGING TURBO S2 ERST
- Is 330 bhp on 95 octane possible ?
- Twin Carb Setup on my Mk3 Fiesta - No Spark
- cossie cold start valve
- steering
- arp stud and nut kit erst
- Mark 5 Escort Master Cylinder COME ON SOMEONE HELP PLEASE!!!
- cvh block
- fitted a new head..cvh..now wont start
- fitting 18" on esc cos
- Head gasket help
- ERST S2 MORETTE WIRING INFO
- spark prob
- mk5 esc wiring/realy fault
- tyre pressure
- help!! escort gti over revving
- cosworth brakes on s1
- Oil Cooler Pipes
- homemade cold air feed
- S2 steering rack
- K+N BREATHER FILTER-FIESTA RS TURBO
- series one fan not kicking in and heaters arnt very hot?
- Megger squirt ecu
- Tail happy Ford Ranger!
- ma erst's fuelling is up and down! help needed plz!!!
- cossie vibration
- Natural Aspirated Cosworth Mk1
- cant crank
- Steering rack Escort
- Fiesta starting Problem
- Getting a mark 4 escort cab help please!!
- Cvh head worn near rockers help needed??? SORTED
- WHAT IS THE CORRECT PLUG FOR 4X4 STG 3 COSSIE
- is it safe to buy second hand chipped ecu's?
- fiesta si with turbo engine ofac ecu problem
- bedding in new engine... what oil????
- smokin fuse box
- Ignition problem
- xr2i running prob
- Dash lights
- xr2i help
- fuel tank
- 2WD Hybrid Turbo on 1992 Escort Cossie......Help!
- Uprating Brakes , hellllp!!!
- corbeau seats into frst.help!!!
- wideband lambda probe and gauge, readings
- Stuttering 1.6zetec
- sirra saphire 4x4 rs 1992 wiring diagram
- Need some advice
- fuel filter
- can anyone help
- ST24 POWER PROBLEM
- Blue smoke but what is it??
- Removal of rear brake valve - advantages/disadvantages?
- 2WD Saff Question
- sapphire door card
- tank question
- Help - Mechanic needed
- Mk5 RS2000 unsettled at idle?
- engine stutter at .4 bar???????!!!!!!!!!!!!1
- how do you identify a 3 bar map sensor
- Can anyone help please ?
- switchable dump valve
- Oil Pressure Gauge Fittings
- Air fuel ratio meter Zeitronix vs LM1
- Brake Fluid master cylinder....
- Hose size ?
- boost drop
- lamba sensor problem
- RELAY CODE
- cleaning samco hoses???
- ST200 Blowing 7.5amp fuse for dash lights can you help??
- which Brake hose...600-03 or 611-03
- Just a quicky
- Right springs?
- escort gti led dash mod
- rs turbo tappet question
- ZOO@S 4 LINK KIT FOR MY S1 RST!!!!!!!!
- COMETIC Multi-layer gaskets
- focus hub nuts
- fiesta wheels fitting????
- Non runner Mondeo
- WONT START
- BD16's and machining
- Handbrake problem??? 4x4 saph
- cylinder head question
- 4x4 suspention question.......
- Cossie misfire
- 3 door starting problem
- long brake pedal.....?
- missfire
- Heated front screen not working
- COSWORTH VIBRAITION
- wiring diagram for diesel relay.ELECTRICTIONS ????????? Help
- Hydralic clutch help!
- millington aluminum block
- electric sunroof wiring dia. ??
- S1 RST start problem...help needed please
- plugs and performance
- Fuse box problem - Fiesta RS Turbo
- Can i fit a Zetec-E head to a focus CGI Zetec R Block
- 1.8 zetec turbo , any advice?
- cosworth cams problem
- coil prob
- Rebuild
- engine swap
- xr3i problem????? or is it???
- boost controller
- What fitting on a Series 1 Turbo Oil Feed Hose ?
- zetec box over cvh?
- Metering Head
- front wheel wobble
- annoying tapping
- Ford Fiesta clutch
- flickering lights
- PEDAL BOX FOR MY MK£ ESCORT???????????????
- Con rods
- rs s2 no gooooooo
- granada/sierra diff.
- rs turbo s2 front brakes
- lsd benifits
- rst brakes
- converting to cosworth/xr3i/rs2000 headlights & side lig
- adjusting koni shocks???
- turbo problems
- 4x4 COSWORTH IN SOUTH AFRICA WONT START PLEASE HELP
- ford fiesta 1998 rear brake adjustment
- compomotive wheel fitment query
- MK3 xr3i gearbox interchangability
- wishbone and fitting
- steering problem
- exhaulst
- Omex 600
- Best head gasket to get?
- 4x4 bad vibration/juddering under acceleration
- oil seperator
- Perfect Power SMT5
- reverse light switch in gearbox?
- petrol/deasil tanks
- s2 rocker cover gasket
- 4X4 COSSY, TICKING NOISE FROM TOP OF ENGINE???
- Turbo technics xr4i breather system filters needed!
- misfire on 4x4 cozzie
- Diesel starting problems
- cosworth phase sensor
- Fiesta RST problem
- mk3 + mk4 door differences
- zvh
- Gearbox/transmission specialists??
- whats this turbo off
- help.
- Whats The Difference
- fiesta RS T - trouble running after few days without use
- need advise (gearbox on s2)
- Lack of oil pressure on Escort RST
- black top silver top zetec 2Ltr??
- cossy gearbox
- Faulty MAP sensor?
- mk3 xr3 rs1600i questions
- Bad running rs
- Remote filter housings
- help please
- Which oil and spark plugs for stg3 saph
- zetec turbo?
- rods
- oil feed on turbo
- HELP rs 5oo cooler
- sierra 4x4 cylinder heads
- gearbox question
- low compreesion cossie engines
- rst wheels on a mk2 xr2
- rover turbo inlet on zetec?
- wheel offset?????????
- Does anyone know????? PLEASE HELP
- will s1 suspension fit my s2?
- Bailey breather on cos?
- over heating
- Fitting Polybushes
- OFAB or OFAC????
- Sierra 4x4 cat question
- clifford 300 signal light question?? bit stumped
- replacing a water pump, escort coss
- -62 Actuator
- Cossie Fuel Tank
- Oil light mystery
- crank possition sensor query
