COSWORTH VIBRAITION
Old Feb 3, 2006 | 07:47 PM
BIG MULL's Avatar
BIG MULL
Default COSWORTH VIBRAITION
I HAVE A REALLY BAD VIBRATION THROUGH THE WHOLE OF MY 2WD COSSIE WHEN I GO ABOVE 90MPH COULD ANYBODY SHED ANY LIGHT ON THE PROBLEM BECAUSE ITS STARTING TO GET ON MY NERVES
Old Feb 3, 2006 | 07:52 PM
martinmace's Avatar
martinmace
get all the wheels checked and balanced would be the first thing to check mate
Old Feb 4, 2006 | 06:46 PM
jon@work's Avatar
jon@work
I had the same - was the propshaft
Old Feb 4, 2006 | 07:31 PM
cossiegreg1's Avatar
cossiegreg1
Dont go over 70... .......
same thing happened to me it turned out one of the tires was blebbed to fuck so check wheels and get em balanced
Old Feb 5, 2006 | 10:46 PM
BIG MULL's Avatar
BIG MULL
Default vibration
cheers for the help, im getting the wheels checked and then the prop so hopfully taht will sort it.
Old Feb 6, 2006 | 09:30 PM
twitchyrear's Avatar
twitchyrear
balancing weight on the prop??has it fallen off?
Old Feb 8, 2006 | 05:04 AM
BIG MULL's Avatar
BIG MULL
Default vibration
do you know where the weight could be on the prop
Old Feb 8, 2006 | 10:02 AM
2001ode's Avatar
2001ode
To check if prop shaft is defective, lift rear of your car, secure it, start your engine on 3 or 4 on iddle speed.
And with good spoot light, look on your propshaft, (on the middle of each half part) if you see strong vibrations or not.
Regards.
Claude
Old Feb 8, 2006 | 08:42 PM
BIG MULL's Avatar
BIG MULL
thanks for the help
Old Feb 8, 2006 | 09:34 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Wheel bearing
Edited to add: Buckled wheel, damaged tyre.
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
