reverse light switch in gearbox?
if i remove this to replace it on a frst is it gonna piss oil out? also are these switches the same on ie escort boxes as long as reverse is in same place... any info please??
Shoudnt loose any oil, if i remember correct the reverse light switch is level with or just above the filler plug/oil level line. If you change it with the car on level ground you will be fine.
The switch is the same on the frst & erst
Dr. Ickxs
Sep 15, 2015 10:15 PM
