Uprating Brakes , hellllp!!!
Old Feb 8, 2006 | 04:58 PM
Dave Zymol's Avatar
Dave Zymol
Default Uprating Brakes , hellllp!!!
I've just put (P reg)rs2000 discs and callipers onto my modded (P Reg)Escort van, they were bought 2nd hand from a local RS centre ,
Since they have been fitted , I can only manage about 60-100 miles before the pedal pressure fades out , i then have to pump them and eventually they fade out to nothing.
I have blead the system about 5 times ( including jacking the back up with both wheels off the floor to help open the valve), replaced the master cylinder with a new one , fit new cylinders on the back , and still the problem persists
W.T.F. am i doing wrong , or have I been sold a dodgy set of calipers?
There are no leaks coming from the system anywhere , its almost like air is being sucked in somewhere.
Can anyone help ?
Dave
Old Feb 8, 2006 | 08:03 PM
NUTS RuS's Avatar
NUTS RuS
Does it have ABS ?
Old Feb 9, 2006 | 05:59 AM
Dave Zymol's Avatar
Dave Zymol
Originally Posted by NUTS RuS
Does it have ABS ?
No Mate , but I'm not sure if the calipers came off one that did
Old Mar 10, 2006 | 09:55 PM
oiled's Avatar
oiled
maybe the master cylinder is to small for the new calipers. but i would expect the pedal to be bad all the time if that was the case
Old Mar 11, 2006 | 01:43 AM
SafeChav's Avatar
SafeChav
If the pedal is fine after u have bled it then progressive gets worse to the stage where u have to "pump" the pedal that means there is air in the system. More than likely to be something leaking break fluid.
Old Mar 11, 2006 | 05:44 PM
xr-stu's Avatar
xr-stu
whats the seal like on the reservoir? sounds like its getting water in there. when that happens the water boils and you get air bubbles......
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
muzzman1
Sep 30, 2015 08:59 PM
