fiesta si with turbo engine ofac ecu problem
Old Feb 8, 2006 | 09:16 PM
fiesta_si_rst's Avatar
fiesta_si_rst
Default fiesta si with turbo engine ofac ecu problem
i have a 1995 fiesta si with series 1 engine fitted i am wanting to fit an ofac but believe i need too change a pin or remove one??? it is currently running rich as it has the si ecu and i had to disconnect the cold air sensor to gain better fuel delivery also got a turbo map sensor to fit once the ofac is hooked up !! can anyone tell me which pin it is or what i have to do to get it running right??? will the ofac affect the pats system??? please help me
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
gingerturbo
Aug 11, 2015 09:44 PM
