puma bearing gone tits
Old Feb 13, 2006 | 02:44 PM
pennylane's Avatar
pennylane
Default puma bearing gone tits
ello, need some technical help. me sister has a puma and it needs a rear wheel bearing replaced. can anyone tell me how i would go about doing this as i have no workshop manaul. do i need a tool to remove the bearing, also i suspect there are certain torque wrench settings which i do not have. any help would be great.
thanks.
Old Feb 13, 2006 | 11:53 PM
NUTS RuS's Avatar
NUTS RuS
If you don't know what your doing should you really be doing it ?
I'd imagine its the same as most fords, wheel off, hub off, bearing off.
Bearing on, hub on and wheel back on
Welcome to Pf too by the way Im sure someone will be along later to help out a little more technically
Old Feb 14, 2006 | 05:16 PM
murdoch1.7zs's Avatar
murdoch1.7zs
u dont need the hub off m8. just take out the the nut. think its a 30 or 32mm and pry the bearing out
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
youngben
Sep 27, 2015 09:37 PM
