COSSIE BRAKES ON RST
GOT COSSIE DISCS AND THE BRACKETS TO ADAPT THE CALIPERS JUST WONDERED WHEN YOU MOUNT THE BRACKETS DO YOU NEED TO HAVE THE FIXINGS FOR THE STANDARD CALIPERS THREADED ON THE HUB AND USE BIGGER BOLTS OR IS THERE A SIMPLE OPTION I CANT SEE CHEERS PEOPLE
