oil feed on turbo
Old Jan 27, 2006 | 08:32 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default oil feed on turbo
quick question can i disconect the oil feed on my turbo to test if its the turbo that is making my car smoke?
thanks tommy
Old Jan 27, 2006 | 09:16 PM
cossie604's Avatar
cossie604
If you do disconnect the oil feed then regardless of wether or not your turbo was knackered....it'll will be after your roadtest lol
Dont do it!!!!!!
Stu.
Old Jan 27, 2006 | 09:25 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
how can i find out wts making car smoke ?? its only once its fully warm
Old Jan 27, 2006 | 09:28 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
even if actuator is fully open
Old Jan 28, 2006 | 09:32 AM
Dave Henshall's Avatar
Dave Henshall
no cos it uses the oil as a bearing - with no oil presure, it would be metal on metal at very high speed - = fooked torbo straight away - it would do teh shaft and the bushes - DO NOT DO IT,
a turbo service kit is only 40-50quid. with new bushed and sels - and is not too bad of a job to do yuoself..
Old Jan 28, 2006 | 01:24 PM
Azrael's Avatar
Azrael
I was adviced by some turbo expert here to do it. You block the turbo rotating part completly, disconnect feed (connect it into drain pipe) and open actuator. Then you can check if it smokes.
Old Jan 28, 2006 | 06:39 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
two ways but think i would rather stick with dave henshall just incase its not the turbo at fault thanks any way
tommy
CAN A HOME MADE BRATHER SYSTEM MAKE IT SMOKE??????????
Old Jan 28, 2006 | 07:18 PM
Fiecos Dan's Avatar
Fiecos Dan
never heard of that, and it cant damage it, if not spinning at all.
Old Jan 28, 2006 | 08:39 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Old Jan 28, 2006 | 08:42 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
big time thinking of trying some nicorette in the inlet
NEED HELP CAN IT BE MY HOME MADE BREATHER POT????????????????????
Old Jan 28, 2006 | 08:46 PM
tonyturbo's Avatar
tonyturbo
yes your breather will cause this. disconnect it completely and you'l see a difference if it is the problem..
Old Jan 28, 2006 | 08:47 PM
Fiecos Dan's Avatar
Fiecos Dan
Yep.
if the breathers blocked/resistristed you might/will get smoke.
Old Jan 29, 2006 | 11:02 AM
Dave Henshall
found that my skoke is caused by a blocked breather -
as a few of u know, mine is a poorly car at the moment - and it only stops smoking when hot -
ive found this is now doen th the breather blocked with mayo due to water ingress throug no 2 cylinder - i blew the lines all clear with comp air yesterday and there is now no smoke
basically, with it all blocked or not functioning properly - the oils only way out frmoteh turbo is though teh back selas as it cant rutrn to teh sump due to teh pressure build up
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Matt Baxter
Sep 16, 2015 08:30 PM
cossirob
Aug 29, 2015 03:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
