View Full Version : Technical help Q & A
- pas conversion mk3
- 16 16v running on single carb?
- cosworth TPS
- erst still smoking
- 1,6 efi pistons
- Zetec billet oil pump gears
- cosworth starting problems
- cvh follower noise ?
- RST Exhaust!!
- Cosworth Cams
- cossy solid lifters ???
- Where is the Sapphire fuel pump relay?
- mk3 escort ,2.0 zetec rev counter wont work
- astra clutch fault but only very little
- mk2 orion locks
- Kent Cams 2nd hand prices
- fiesta rwd cosworth
- escort td juddering on half throttle
- please help with my mk5 escort cabriolet turbo!!!
- Focus Rs Bottom End
- Escort on EFI sensors
- How to fill gearbox with oil?
- 3 door Cosworth headlight problem
- 3door cos brake judder
- what size valves
- ign amps on cossies
- Mondeo lights "pulsing"
- Whats the difference between.....
- Cossie engine leaking oil
- will an efi in tank fuel pump run an mfi
- rs turbo
- s1 paddle clutch
- missfire help!!
- torque setting
- Cossie diff
- does this make sense?
- 1.8td air ingress
- cossie fuel pipe diameter
- Tyres!!
- How to install Elextric waterpump in a Cossie 4x4?
- T5 gearbox rubber boot - Where to get?
- group A INSERTS
- mondeo tdci
- s2 staring Prob,s
- fitting a starter motor to a mk3 Mondeo TDCI
- suspesion Q
- Poss gearbox failure rs s2 turbo
- Relays blowing!
- Oilpump
- st170 pistons
- XR4 driveshafts / half axles to Cossie Diff
- 2WD Sapphire Cosworth No Spark
- loom
- Mk 6 fiesta
- sump adapter mAle - Male
- Fitting supercharger???????
- rs turbo running problem
- Engine Rebuild - Crank
- Focus rs clutch
- smoking cossie
- ford escort cvh-carb conversion: fuel pump/swirl pots
- Jreg fiesta turbo ecu and engine loom help?
- Escort RS2000 EGR
- xr3i MFI air / fuel metering
- Gearbox Paranoia
- ERST Cossie Management issue
- Siemens injectors
- Mondeo automatic transmision problem
- granada cossie into 3 door/...........
- ZS Turbo coverion 5th injector
- e36 316i coupe bmw juddering in first
- mfi pressure actuator please read need advice HELP !!
- Alternator info required
- Tick over proplems on rs 2000 mk5
- dyno rolling road question
- Fiesta RS Turbo running Problems
- Earth strap
- 2 avo coilovers leaking can they be fixed,on escort gti
- Missing when hot after 4500revs
- ACT temperatures
- t3 with .63 exhaust
- escort mk3 front hubs
- Gearbox oil
- sierra changing fom auto to manual and bhp info plz
- mk4 escort nasty judder
- T34 turbo spec info required
- escort rs 2000 help L Reg
- decomp plate
- wont rev over 3,000 pops and bangs
- series 2 rs turbo metering flap adjustment
- SportKa 1.6 tuning... help please
- 4x4 Saph inlet & throttle body vs. big turbo Escort.....what's the difference?
- FAO of Tabs or any mech
- Aftermarket rev counter. Help needed please
- zetec turbo boost problem
- S2 RS Turbo won't start
- Kidney box removel
- 3 door coz with hispec calipers+hydraulic handbrake(how to bleed)
- 88 spec or 90 spec header tank series 2
- Standalone ecu
- turbo rebuild
- Problems when Launching ERST
- walbro fuel pump da-27 305 LPH
- Fuel rail adaptors for remote fuel pressure regulators?
- Engine transplants
- lighting problem
- 4x4 cos oil pump cover bolts
- Cruise control Mondeo/Focus
- boost valve
- removing rear shocks from s2 ?
- escort temp sensor problems (HELP)
- Fiesta mk5 ZETEC S turbo conversion
- cosworth pistons
- technical drawings Cosworth BOA chain tensioner
- escort gti gearbox
- turbo carbs
- rs2k timing chain change ????
- cr pinto
- dump valve has just been fitted
- xr3i MFI
- Central locking....
- How easy/hard is it....
- CVH crank question
- radiator
- 2.0 Tdci smoke & lumpy idling
- Any one know where to plug the trip computer into the loom????
- Sierra fuel pump problems
- gti oil pressure switch, Washer or no washer?
- car wont idle wen hot do u think it will idle if i get a dump valve ???
- cosworth with no spark
- wheels & tyres off mondeo for van
- cvh bike carbs,whats best r1, r6???.....help!
- cosworth headbolts and gasket
- MK4 Fiesta heater problem!!!
- cosworth intereor
- s2 rear roll bar
- mk4 escort bottom arm bushes
- Rs turbo Gearbox oil seal
- focus st 170 question
- Fiesta Rs Turbo cuts out when I put headlights are on!
- Cosworth cam followers
- Help Escort cosworth Brakes
- zetec conversion ecu problem
- zetec turbo tapping noise
- t3 info
- sierra cosworth smoking under acceleration
- need some help please
- Mk1 Fiesta engine conversions
- Alternator wiring. Need help please!
- engine rebuild probs
- Turboing a ST170?
- xr3i mk3 power mods??????
- rs turbo to 2.1 wiring pls help
- can any body help
- Rs Turbo...... Help!!!! UPDATE...... PROBLEM SORTED....
- Cossie water in oil (not as simple as it sounds)
- 1.6 CVH Core plugs
- T5 box oil
- fiesta rs 1800 lambda problem
- were to get my rs turbo chiped in devon
- my rs turbo s2 wont idle wen its warm ??
- 1.6 cvh cylinder bores
- rs turbo 1989 wont idle wen its hot
- rs turbo 1989
- Fitting rs2000 manifold on mk6 escort1.8 zetec
- t3 turbo fitting help
- escort diesel
- running zetec on 40,s
- Zetec turbo
- identifing ecu and chip
- RS Focus - Tuning ?
- 3 Door feul Pump Fuse/Relay
- XR3i to rs turbo conversion
- Mk2 Escort Rear Axle - What power?
- focus 1.8 clutch
- Large Yello relay in saph f/box?
- 1.8 TD engine
- urgent help needed
- Nissan primera driving me mad blowing fuses
- where to get centrecaps for centre lock wheels
- putting an 1800rs in an xr3i??????
- capri2.9 conversion ?
- non starter: injectors not pumping
- erst too much brake pedal travel
- Problem cahnging gear.
- mk3 escort brake conversion
- Mk4 escort van leaf spring bushes
- MK2 Escort Coil overs
- Bmw cosworth
- are all fiesta mk3 fuel pump plugs the same?
- ZERO boost
- s2 rs starting problems
- Can someone identify this for me?
- smoke after idle HELP
- Cossie Spluttering?
- gsi with msd code
- sierra 2 litre injection wiring
- mk6 rs2000 escort light problem
- enigne bearring replacement
- chips
- rs2000 oil ??????
- chips
- Brake upgrade?
- lsd box (escort)
- bonnet pins?
- fuel filter
- Metering Unit full of petrol, then pissed it EVERYWHERE!
- any help
- cvh to zetec ignition system help/advice wanted
- Smoke Doin my head in. (head)
- DIY zetec turbo block drilling?
- Engine failure maybe after oil loss?
- Turbo took a proper dump!
- Fun with the ZVH Guess that noise time!
- Steering wheel
- RS1600i Turbo wont start!!
- Mk3 cortina 2 door window rubbers
- engine pinking in gears 4 n 5 helpppp!
- sandblasters
- mk2 mondeo 5stud conversion
- Xr3i started "smoking/burning" oil? Help!
- series 2 rs turbo metering unit fault air in the fuel
- cosworth boost problem help
- focus bluefin
- focus cruise control
- wanted 1.6 cvh parts
- CVH Turbo Into a westfield
- Setting up a cossie
- engine swap
- saph 4x4 hydraulic clutch conv ??
- Focus Doors Locking Whilst Driving
- smoking 2wd under load
- xr3i 130ps tickover up and down
- Fiat Brembos
- diesel injectors
- zetec turbo into 3door cossie
- Leaky sump
- CTS Stage 2+ Gearbox worth the money??
- mondeo smoking
- Standalone til Sierra Cosworth - better?
- Oil Pump
- Which Fuel Pump for Stage 3 ZVH 2.0???
- MK4 Escort 5dr and 3dr interchangable parts.
- Zetec SE cylinder heads..
- meltin fuses!
- fuel pump question
- ACTUATOR
- Idle screw Cosworth
- main beam (s2 rst)
