mfi pressure actuator please read need advice HELP !!
hi i have a problem with my series 2 rs turbo it will not start and run theres no fuel getting to the injectors but if you unplug the white plug from the rear of the metering unit it gets fuel at the injectors and it will start and rev up but not tickover the tickover could just be due to it needing set up any ideas on this thanks for your time,mathew
JK12
33
Apr 26, 2021 12:09 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
