Fiat Brembos
Old Apr 9, 2009 | 08:43 PM
Phil2002's Avatar
Phil2002
Default Fiat Brembos
Has any fitted the brembos off a fiat coupe turbo onto any kind of ford may be able to get some nice and cheap so was woundering if it can be done.
what size disk can i use as i'm currently usinf 300mm st170 disks.
cheers,
Phil
Old Apr 9, 2009 | 08:48 PM
marky_g's Avatar
marky_g
Fleet Manager
i looked into buying some either fiat coupe or 406 coup but came up expensive considering u'd need brackets and stuff made
Old Apr 9, 2009 | 08:58 PM
LHD220Turbo's Avatar
LHD220Turbo
seen them done on a saff from a 406 anf fiat coup; if you can get the calipers cheap enough then go for it
cant tell you much more than that tho
Old Apr 9, 2009 | 09:00 PM
Toe Knee's Avatar
Toe Knee
Anything will fit on anything within reason with the right brackets made up for it and the right size wheels being on the car, comes down to if you can source/get made up some brackets to space the calipers out to the size of discs you are using!!
Old Apr 9, 2009 | 09:01 PM
Can you not just get some focus rs calipers.
Old Apr 9, 2009 | 09:06 PM
LHD220Turbo
probably not, he said he can get some brembo's cheap
Matt
Old Apr 9, 2009 | 09:09 PM
Phil2002's Avatar
Phil2002
not for the price of these fiat ones i have my eye on!!
cheers,
Phil
jason_nike
Aug 18, 2019 10:53 AM
Nov 1, 2015 06:53 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
NC53
Sep 13, 2015 03:05 PM
focus2351
Sep 9, 2015 09:33 PM
