identifing ecu and chip
Old Apr 17, 2009 | 06:06 PM
raggey's Avatar
raggey
Default identifing ecu and chip
Well
Here i go again I am wondwering if the chip in my ecu is a 330 bhp chip and the ecu is a l6
On the chip it says sapp 803.3bar power egn.
The ecu says on it weber italy
iaw 045 w45 .06/
med l20 -70
fabbricato da marelli autronica
The reason I am asking is a lad at work says a ecu should have a vac pipe to it, but mine hasnt the car seems to run not too bad but im hoping to get it set up properly.
the thing is its in a kit car and I have bought most of the parts from flee bay [ I can see paul from rs laughing now ] so I am just trying to identifiy the bits to make sure what i have is what its supposed to be.
Help please Paul.
Old Apr 17, 2009 | 07:44 PM
LHD220Turbo's Avatar
LHD220Turbo
Originally Posted by raggey
Well
iaw 045 w45 .06/
med l20 -70
Help please Paul.
its a L6 ecu (as fitted to standard 2wd saffs), and i guess its a power engineering chip
i'm not sure what you mean with a VAC pipe to the ecu?
the chip should have a serial number to it, phone power engineering and confirm the spec the chip is for and get them to tell you what the CO% should be at idle
Matt
Old Apr 17, 2009 | 07:59 PM
velocity's Avatar
velocity
as above,
also there are no vacuum pipes fitted to any l6 l8 p8 ecu's etc. your friend may be thinking of an rs turbo which has a different ecu and a vacuum tube connection
Old Apr 17, 2009 | 08:55 PM
raggey's Avatar
raggey
cheers lads I have emailed power engineering see if thet can tell me about it but were do I find the ser no do i have to pull the sticker of
Paul.
Old Apr 17, 2009 | 08:58 PM
LHD220Turbo
Paul.
take the lid of the ecu and the serial number will be onto the chip......if its got one
if you dont have a serial number, please make sure you get it set up with proper wideband to check fueling, or get a new chip
i use MSD chips and its superb!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
RSmark84
Sep 13, 2015 01:29 PM
