DIY zetec turbo block drilling?
Hello,
I'm at the stage where I need to sort out the breather for the block. I have sent the sump to Ian Howell to install the turbo drain so thats sorted. I have focus RS pistons and rods, inlet sorted and ERST exhaust manifold with cossie T3. I dont really wan to drive the block to lincoln to Ian just for this job so...
How difficult is it to do the block and what do you use as a stub, where do you get the stubs.
Any help gratefully received.
Mart
Mart
