3door cos brake judder
i havent checked anything yet but was just wondering if it was a certain problem but obviously it can b a number of things, ill have to get it sorted because it gets annoying.
also i find the brakes arent that good compared to my old saph 4x4!!
also i find the brakes arent that good compared to my old saph 4x4!![/QUOTE]
You defo have something very wrong then, they should feel substantially better.
It is most likely warped discs, why they are warped could just be age/use or very likely one or more of the 8 in total pistons sticking, so a good check all round needed.
tabetha[/quote]
so your saying the brakes should be better than the saph or just as good!
i have driven 2wd saphs with very sharp brakes shud the 3doors b the same!!
tabetha[/quote]
