escort diesel
Old Apr 18, 2009 | 02:18 PM
n13los's Avatar
n13los
Default escort diesel
can someone tell me if there is a bleed screw on the fuel pump? if so which one is it?
there is on the side of the pump facing the radiator (8mm spanner) and one on the back below the injector pipes (about 10 or 11mm spanner). thinking it will be one of these two but dont wanna go undoing random bolts on the fuel pump!!
its an r reg van non turbo if that helps
cheers
Old Apr 18, 2009 | 02:26 PM
RS 5tu's Avatar
RS 5tu
iirc there is a black button type plunger to bleed the fuel. Its on the side of the engine on top of the fuel filter.
Old Apr 18, 2009 | 02:31 PM
n13los's Avatar
n13los
done that all bleed & its working, i understand the primers can be a problem but the primer is getting hard after a few pumps and i pulled the supply pipe of the back of the pump and there was loads of pressure, cracked the injectors off but there doesn't seem to be any fuel coming up. dont want to crank it over too much if the pump is dry.
Old Apr 18, 2009 | 02:37 PM
RS 5tu's Avatar
RS 5tu
could be the solenoid?? in the fuel pump it may not be lifting up that could be causing no fuel to the injectors but you would still get fuel to the filter.
Old Apr 18, 2009 | 02:38 PM
RS 5tu's Avatar
RS 5tu
well i am assuming it wont start?
Old Apr 18, 2009 | 02:41 PM
n13los's Avatar
n13los
got fuel to the filter, got plenty of fuel to the pump just nothing after. was running fine, changed the filter now it wont start. will cranking it over do any damage to the pump?? if not i will just persevere with it.
cheers
Old Apr 18, 2009 | 02:48 PM
RS 5tu's Avatar
RS 5tu
If the fuel is getting to the pump but not coming out then the problem is there somewhere check the wire to the solenoid sound like its not opening.
Old Apr 18, 2009 | 05:57 PM
n13los's Avatar
n13los
can get it to run for about 5 seconds if i build the pressure right up in the line between the primer and fuel pump, soon as the pressure is gone it cuts out. any ideas?
where is the stop solenoid mounted?
have looked on the pump and cannot see it, there are some wires going behind the cover on the back of the pump but think they may be for the immobiliser.
also, how much fuel is meant to come from the hand primer on each pump? im getting about a teaspoon full which is coming through quite frothy, this leads me to think this is knackered.
just been to halfords to see if they keep them in their imense parts stock, after clarifying that i didn't want a 'ham primer','grey primer' or a syphon pump, being told that they didn't exist and giving 3 of there well trained staff a lesson on how a diesel engine works i gave up.
gonna get a new hand primer on monday and have another go. fingers crossed
Old Apr 19, 2009 | 09:34 PM
cabriolet's Avatar
cabriolet
sounds like primer b warned 95 odd quid new did u take off return pipe with ignition on and pump the primer until diesel came out the return
Old Apr 20, 2009 | 09:56 AM
n13los's Avatar
n13los
thanks, thats what i think it is.
used to work at a ford dealer, just been quoted Ł35 for a ford one. going to get one at lunchtime.
Old Apr 21, 2009 | 07:39 AM
n13los's Avatar
n13los
fixed it.
if anyones interested, it was the hand primer. the old one was pumping fuel but only about a quarter of what the new one does, and it looked like it was drawing in air. still took 4 or 5 attempts but a few squirts of brake cleaner down the inlet helped her cough back into life.
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
atm
Sep 7, 2015 05:39 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
Bighandsuk
Sep 2, 2015 05:23 PM
