Cossie Spluttering?
Old Apr 14, 2009 | 06:38 PM
moonstone_cossie's Avatar
moonstone_cossie
Default Cossie Spluttering?
just took my cossie out today for the first time this year and she is spluttering just before she hits full revs.
she is low on fuel and fuel is old.
i got a new msd chip in her before she was put in for winter and was doing the same with good fuel but was low. would the new chip do this when low on fuel or simple answer just put more fuel in a try it??
just wanted an option before i put more fuel in. oh and it doesnt do it in 1st iirc! just 2nd 3rd never tried 4th or 5th
it sounds like low on fuel or bad fuel and plugs cant run it but im prob wrong
thanks matty
Old Apr 15, 2009 | 10:17 AM
How old is the fuel filter ?
Bacteria love the conditions that exist with rarely used cars, I would at the very least change the fuel filter first, mine is done every year.
Old Apr 15, 2009 | 10:53 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Stick a gallon in it, and see what happens.
Then go for the other simple things like rotor arm, dizzy cap, etc.
Old Apr 15, 2009 | 12:47 PM
Trist's Avatar
Trist
Condensation in the MAP sensor pipes also take them off give them a blow out. change fuel filters stick some fresh fuel in and poss plugs.
Old Apr 15, 2009 | 01:16 PM
moonstone_cossie
fuel filter isnt that old was put in just before she was put away for winter last nov.
will put more fuel in and take it for a really long drive and if she is still doing it ill check plugs etc
thanks for your replys
matty
timsrs
Nov 13, 2018 11:48 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
