T34 turbo spec info required
Hi, ive brought this turbo,just would like to know is it a T34. also which model did it come off. How easy is it to rotate the core or compressor around? could anyone point out which is the oil and water.
i would like to know, ive spun the blades/shaft and it dont spin freely, would you guys recommended putting oil down the oil line to lub the bearings? the shaft has no play.
Thanks
spenc
Thanks
spenc
turbo's are very hard to identify, it looks like a cossie turbo, but i cant be sure.
it looks to small for a t34, looks more like a t3 to me
look at the exhaust housing and does it have .48, .55, or .63 stamped into it?
if the shaft does not spin freely, i suspect the bearings are shot
here are some pics of a comparsion of size compared to
right K24 KKK, IHI VF 22 and hopefully a T34
as you can see the size difference between the core's and compressor housing.
The T34 when compared to the a T3 (silimar size to the K24) is about twice its size.
how can i find out a correct model? i know its from a Escort Rs Turbo
also i have fixed the issue with the shaft spin, it was due to carbon build up between the housing. ive now opened and cleaned the core side and it spins perfectly.
so is it a T34? from the replies im a bit confused
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
