lighting problem
Old Apr 24, 2009 | 08:31 AM
BR1GG5Y's Avatar
BR1GG5Y
Default lighting problem
The car is a MK4 xr3i. Suddenlly noticed this morning that if I have the head lights switched off and press the brakes. My side lights on the front come on.... doesn't matter if the engine is running or not. Have made no changes to any of the electricals recently. No idea how long it has been doing it.
ideas?
I do have a multi metre.
Old Apr 24, 2009 | 01:19 PM
lurch1977's Avatar
lurch1977
Bad earth on the rear lights by the sounds of it
Old Apr 24, 2009 | 05:37 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
u changed the bulb recently??
Old Apr 24, 2009 | 06:18 PM
BR1GG5Y's Avatar
BR1GG5Y
not swapped the buld, but there is a dodgey connection, where the loom plugs into the drivers side rear light. I have cleaned the connectors, which was over 2 months ago and if did fix the faulty drivers side brake light which some times works and other times did not.
Surely this cannot affect the front side lights??? Will check everything tomorrow when I will have a friend to press the brake pedal when I need it.
Old Apr 25, 2009 | 08:09 PM
cabriolet's Avatar
cabriolet
100 percent rear light earths feeding back through the sidelight circuit from the brake light circuit
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
