2WD Sapphire Cosworth No Spark
old fords only
![Unhappy](https://passionford.com/forum/images/icons/icon9.gif)
Been driving the car for about 6 months with no problems, no missfires etc, drove home from work last night and stopped in town, came back out 10 mins later and the car would turn over but refused to fire up.
Had to phone the AA for a tow home. The AA guy said there was fuel getting though but that there was no pulse going to the coil.
Got the car home and tried a known good phase sensor and cleaned terminals, also cleaned terminals for ignition amplifier and CPS.
HT leads, phase sensor, spark plugs, coil, dizzy cap and rotor arm were all brand new a month ago and all genuine parts.
Tried starting the car again this morning and the fuel pump primes as normal so i have ruled out the CPS for now.
An ex ford mechanic suggests trying a new ignition amp but wondering if anyone has any other suggestions before i go and start ordering stuff?
Would be nice to get this running as my fiesta is off the road just now and i'm having to take today off work to see if i can fix it/sort out something else to drive. Thanks in advance.
old fords only
Thanks guys i will double check the phase sensor but even the old one i took out a month ago looked in good condition.
Barry R do you remember which relay you had to change? Was it one of the ones under the glovebox area?
There is a yellow relay under there with a GM logo on it so i guess that isn't standard.
The girlfriends RX-7 is in getting mot'd just now so hopefully that will pass and i'll have something to drive or a workmate has offered a loan of a diesel pug 306 for few days. Would be nice to get my own car back on the road asap tho.
Just ordered a set of sensors and an ignition amp along with a few other bits to give it a service.
09-10-2015 07:38 PM
