Kidney box removel
Right im just removing the kidney box, now I presume the adaptor goes in the block, but what do you do with the little rubber pipe your left with?
I assume you are fitting a breather kit, good idea anyway.
The little breather pipe goes to the plenum cover through a one way valve(boost shut valve), so simply unscrew this hex shaped valve with pipe on and put a 1/8th NPT grub screw in there to seal it.
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
