View Full Version : Technical help Q & A
- Fitting uprated 4 bar fuel reg (cosworth)
- 1993 escort rs2000
- Megasquirt my pinto?
- Connect timing belt
- Service info requ. please.
- Mk4 Escort full suspension change?
- Focus tddi glow plug quality in question
- fuel in sump cosworth
- Fitting a Toad Ai606
- 02 focus blower fan not working
- 1.8 zvh
- escort fault
- Focus EM light, possible Lambda
- justing checking!
- Possibly a stupid question - Can I keep same ECU?
- overheating under load and bottom radiator hose cold
- ford maverick 2.0 weak spark
- boost keeps climbing????
- clutch zetec turbo
- rebuild Zetec Black /silver top
- Performance Exhausts Escort Mk4.... cant choose...
- Mondeo TDCI non start
- saph cossie 4x4
- cossie rear wishbones, 2wd, 4wd same??
- Cossie regulator, after the injectors??
- Interesting Cosworth fueling problems.
- ford escort mk5 rear door problem
- Fiesta rs turbo oil return feed.
- Granada Mk3 Diff Noisy
- Ka Brake problem
- Help please with Walbro Fuel pump??
- Mk1 focus 2.0 ESP fault
- Can a heated windscreen be added?
- mondeo clicks when key turned.
- Fiesta Mk4 Clutch Issues
- Who can map megasquirt???
- Sierra fuel tank
- Crankcase pressurised.... :(
- door pin removal on mk3 fezz.
- dohc sierra ignition vs zetec trigger
- is it possible to convert EFI pinto to points?
- What Clutch
- ford cougar
- 2 litre pinto question ( air filter an red cables )
- 2001 Fiesta 1.25 ghia....Water Leaks
- 02 Focus ST170 various stuff
- mk1 mondeo
- stainless steel hose, Acrylonitrile-Butadiene and synthetic-nitrile, differences?
- Sapphire 4x4 engine loom suppliers??
- Focus TDCi mk1: Loose pipe on turbo?
- Limp reving
- Focus drivers door central locking
- sierra cosworth wiring
- sierra shocks
- Sierra 4X4 - Turbo Identification Question
- focus engine change help
- any ideas on what this is
- fuel pressure regulator
- vss
- escort cosworth st fuel pump relay
- Mk3 escort zetec conversion questions
- Oil Filters CVH Turbo
- Puma 1.7 Problem
- P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
- Clutch or box problem .... ?
- mk2 fiesta front bump stops missing
- turbo specing for 450-500bhp??
- ABS on Cosworth
- No power HOT! oil
- my focus
- fitting recirc valve to focus rs?
- Ford sapphire
- Car Tax
- Anyone used one of these? S2 RST
- MK2 Ford Focus RS - OIL PRESSURE GAUGE QUESTION
- Ford Capri 2.0 I EFI
- Fiesta Mk3 wheel bearings...
- Heating will not come on
- escort gti running fault plz help
- fiesta running bad
- oil n overheating?
- mondeo auto gearbox
- No 4th gear! VSS!
- Low Compression turbo conversion
- fuel problem
- Fiesta 1.4 tdci Cooling pipe
- going down
- T3 flange turbo specs
- 2.0 zvh management
- iscv
- cj.flyer
- mondeo tdci
- t34 help
- Transit petrol Pats/Ecu problems
- Mk1 Cortina fuel sender ohm resistance
- Will This Turbo Kit Fit My 1.6 Zetec
- Using water....Help!
- confuesed.com
- Mk1 Capri - Cossie YB Advice Needed...
- rs2000 seats in mk5 fiesta??
- tddi inlet differences??
- Removing rear wings properly. drilling out spot welds..
- zvh 1.8 timing help i think?...
- solex 45's on a pinto?
- Transit Connect Wheels
- focus st225 pod removal
- Mk4 escort cab
- usb
- why wod
- MK5 Fiesta anti-roll bar bush change
- Sierra 4x4 info req'd
- mk 2 mondy alarm ?
- Cosworth Flywheel & Clutch ?
- '52 Plate Fiesta 1.4 TDCI won't start! Help
- Cosworth 4x4 Wiring Loom Identification
- zetec turbo engine oil
- Sierra brake help
- 4x4 SAPPHIRE RAD FAN SUCK OR BLOW?!
- overboost and blown KEJetronic please advise
- rs turbo wont start?
- Engine change
- Higher amp battery ok?
- 3 bar MAP sensor
- Siera 3-door technical drawings...
- Where can i get an Electronic Power Steering Rack
- rs2000 van help
- Rev counter in cossie converted Escort
- escort s2 rs turbo running really hot
- clio dci starting problem HELP
- RE-SPRAY??
- Undoing puma crankshaft pulley bolt...
- wrong engine oil ??
- Series one front end
- Early misfire after rebuild of engine, help?
- Fuel pump rewiring....
- 2 way or 3 way manual boost controler, bleed valve
- MFI Fuel Pressure
- non interference engine?
- Mk5 Escort steering rack repair/replacement options
- Focus Gearbox problem
- Cleaning ERG Value
- what engine to put in my xr3
- no faults
- email address for buypartsby
- Mk1 Focus broken hose
- Difference I'n actuators
- braking
- Ka RST - Missing under load? 18/12/11
- slight misfire when driving
- Intercoolers!
- Ford/Denso sat nav update
- 1.8 zetec
- does any
- Saph 4x4 Front diff bolt size
- tacho issue
- Mocal oil cooler fitting location
- 1600 zetec into orion no spark!
- 2006 Ford Fiesta ST ABS problem
- Best place to buy heater cores
- escort rs2000 wont start
- escort zetec engine removal
- focus not starting
- yb bottom pulley touque settings
- whats the best way to make a 400+ bhp. cosworth...?????
- heated winscreen not working
- Fiesta starting problem..
- Cossie 4x4 - wheel hub bearing
- Ecu
- throttle
- Is fuel pump same xr2i/xr3i??
- Ford 2.9 EFI
- fan
- will
- help / advice needed
- 2000 Focus 1.4 temp gauge
- Mapping...
- Rev.Counter Mk6 Escort
- flashing glow plug-engine cut out!
- Central locking nightmare
- maf sensor
- Mk4 Master Cylinder help :(
- can i put a 2L maf sensor into the 1.8L housing?
- Focus 1.6 studio power loss
- Focus TDCI 2003 115ps starts and then stalls ? Help!
- Ford Mondeo Mark 3 1.8 petrol LX
- Cossie loom question
- Fecking 2wd clutch cable
- Galaxy 1.9 tdi VAG VW Limp mode power drop
- New Focus Titanium March 31st 2011
- Spray painting over Chrome Rims
- Bluefin superchip
- I put
- 1.8 CVH vacuum spaghetti
- ignition wont turn because of steering lock?
- Fitting LSD to ford ib5 gearbox
- Pulsar GtiR Clutch issues???
- RST radiator broken bolt
- any diffirent between the 205 cosworth block and the pinto
- New Clutch Not Norking
- Focus RS Alarm Fob
- MK3.5 Fiesta Driveshafts
- 1.8 CVH exhaust manifold
- Zetec sparking plugs... Heat range!
- ATL fuel gauge - Will it with a VDO sender??
- Silvertop Zetec guess the engine part!!
- Advise on frst running fault
- Ford Focus 07 Starting issues
- Ford focus 1.8tddi head rebuild running problem
- steering column question
- focus st forge dump valve blanking plate
- mk3 escort 4spd to 5 spd conversion!!!
- Brake fluid
- mk1 focus rs brakes on a series 2
- RWD Zetec auto
- zetec valvetrain and the quest for 600+ bhp....
- Focus rs mk2 problem
- meta
- Mk4 clutch pedal
- URGENT help needed! clutch problem
- focus
- Threads asking for Car Stereo codes are not allowed.
- YB cylinder head core plug
- Paint Code
- rear spring removal on three dr?
- how do i put on a tps on a escort gti
- mfi loom fitting to a mk6 escort
- fuel type
- modified engine mounts/ lower arms?
- What engine for my mk4 Escort?
- Fiesta RS Turbo Running Problem !!
- HELP
- Mk4 Fiesta Courier
- DIY windscreen fitting, or fitter in S.Yorks/Notts
- What to use as a Cosworth Sump Breather Adapter??
- steering fault
- ecu on escort gti
- hard to start KA duratec.
- Sierra handbrake light flickering
- Zetec zvh pistons head compression
- 90 Amp Alternator?
- 4" exhaust pipe where from ?
- zetec turbo or zvh
- Saph cossie headrest removal
- Zetec turbo gearbox advise ib5!
- mondeo mk4 bush replacemet
- escort mk2 with cozi turbo engine, wont idle when cold
- ABS system on a MK1 Focus ST170
- Mk6 rs2000 fan not cutting in
- ignition barrel removal
- Radio staying on
