Ford focus 1.8tddi head rebuild running problem
Old Sep 19, 2011 | 01:29 PM
doingthis's Avatar
doingthis
Post Ford focus 1.8tddi head rebuild running problem
Hi all,ive just joined and this is my first post.
I have a y reg ford focus estate 1.8 tddi, i brought this very recently to save money on fuel cost, insurance etc.
My plan was to drive to poland in it where i was getting married.
I done the usual oil change fuel filter etc and the car was running like a dream.
Anyway got as far as berlin in it when i pulled into a petrol station and it just cut out. After a very long wait for the breakdown guy to arrive he said bell had slipped a tooth and engine was 'kaput' anyway got it recovered and my mechanic looked at it and said it snapped a camshaft belt bending a valve or two in the process when it was restarted.
So we changed the belts (ford original) water pump (why not as were changing everything else) head gasket set bolts, and of course all new valves.So a head rebuild
So he has done that...no problems got it started with easy start and the engines running.Alot of smoke came out at first but started to clear.Its running but it seems to be hunting for revs and wont start without the easy start.He has tried diagnostics but nothings to be found there infact it came with ford escort which the tddi is from but still nothing to be found, he has cleaned the erg valve checked the tapits and shims but nothing, belts are timed correctly. He thinks maybe fuel injectors but he dont really know. Please can someone help me with this because this is getting very expensive and im at my wits end
Why would the injectors be at fault now when they were working before If its running could it be something silly or has he not done something when rebuilding it. Or could a sensor be gone?
A few of his mechanics friends are stubbed to.....
Is there any diesel gurus out there who are familiar with this problem or who thinks they know what it could be????
Thanks for any replys good or bad in advance!
Old Sep 19, 2011 | 01:39 PM
foci's Avatar
foci
Timing sounds out. Camshaft 180 deg out???
Old Sep 19, 2011 | 01:58 PM
doingthis's Avatar
doingthis
Thanks for the quick reply mate, well he says that he has checked the timming and its on point as for camshaft 180 deg out ill ask him about it.
I thought the camshaft could only go in one way otherwise wouldnt it smash everything up again?? please educate me as im trying to understand as much of it as i can.
So if the cam was out 180 deg it would still run? but run rough yh?
cheers
Old Sep 19, 2011 | 02:36 PM
Sp3no's Avatar
Sp3no
Timing an engine 180 degrees most of the time will not cause any issued apart from non running, i once timed an engine 180 degrees out and it was fine once the mistake was spotted, its possible because the cams turn at half the speed of the crank so the timing marks will line up when 180 degrees out. You will have basically timed the engine to BDC instead of TDC.
If the engine is running then i suspect the timing of the cams is ok as it would not run at all 180 degrees out.
check the fuel pump timing.
new glow plugs
check for air leaks
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
Zoggon
Aug 10, 2015 10:39 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
