YB cylinder head core plug
Old Sep 17, 2011 | 04:35 PM
BRAMMER's Avatar
BRAMMER
Default YB cylinder head core plug
I have removed the front one with screwdriver and hammer but the ones at the side are a little more Steuben, any tips?
also and once they are pushed in how do you get them out -
any advice
Old Sep 19, 2011 | 11:21 AM
BRAMMER's Avatar
BRAMMER
Just for reference - 2wd head
The exhaust side plugs have a seat behind the top of the plugs so hit them at the bottom with a punch and hammer until they turn then pull through with long nose grips
The front just pushes through and can be removed through the hole for the thermostat
The inlet side don't have any seat and go straight through - i would recommend drill and tap the centre, fit as socket over the outside of the plug resting on the head and screw a bolt with nut & washer though the socket and manually wind out.
To refit they are slightly off shape so get the best fit - smear a very small layer of silicon on the outer edge and knock in straight with socket and hammer
Job done
Well thats what i have done
massivewangers
30
Oct 1, 2015 07:40 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
