Galaxy 1.9 tdi VAG VW Limp mode power drop
Old Sep 21, 2011 | 07:55 PM
fodens40's Avatar
fodens40
Default Galaxy 1.9 tdi VAG VW Limp mode power drop
Hi Guys, I have a p plate 1.9tdi,old but tidy,its done 200,000miles & is my jukebox transporter,Pulls hard with turbo wine(normal boost noise) up to 3,000rpm,Then power drops out& it will just manage 2,800rpm & looses all pulling power,If I turn key off & on while driving it resets & will pull ok .AS long as I dont try to drive hard or go above 3,000rpm(boost hard)? I have changed MAF & if anything its worse.It has had a new turbo 2,000miles ago.all filters are good & no loss of turbo boost,all pipes are ok. Nothing is comming up when we plug it in on 2 different Dio's Snap On & Bosh
So what is the VNT & where is it? what sensors pick this over boost up & where are they?I dont think its the cat as It will go like a train up in gears & only when its in 4th/5th & getting lots of turbo boost will it go Limp.
I know its just a daft thing as it is working fine all day every day as long as i dont push it.Now well pissed off!?????
Old Sep 25, 2011 | 04:29 PM
andi-p's Avatar
andi-p
count the flashes as its the fault code. I have had loads do this and its the brake pedal switch hope this helps
Old Sep 29, 2011 | 12:17 AM
fodens40's Avatar
fodens40
Default galaxy
Right thats interesting as the brake light warnings light up untill I press brake pedal (hard) & the brake light switch messes about a bit you need to press hard to get the brake lights to work.So how the hell is it connected to the limp mode thing them? cheers Rob
Old Sep 29, 2011 | 07:35 AM
cossie.con's Avatar
cossie.con
Smile
Intrested to find out if this repairs it as I have a fault VW bora(same lump)
Old Sep 29, 2011 | 08:01 AM
B19 JUB's Avatar
B19 JUB
its a dual action switch i believe.works for brake lights and also tells engine management when your braking.could be incorrectly adjusted so it thinks your foot is on the brake and cutting fuel pressure maybe when your accelerating.try readjusting it first
Old Sep 29, 2011 | 04:48 PM
andi-p's Avatar
andi-p
Thats pretty much what i was going to say but if the brake lights dont work until the pedal is stamped on it wouldnt be the fault. The contacts corrode inside that causes resistance and ecu say no
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
AJC
Oct 1, 2015 06:47 PM
SMILER258
Sep 28, 2015 09:04 AM
Mr S1
20
Sep 27, 2015 04:06 PM
