HELP
Old Sep 15, 2011 | 10:57 PM
dlf3yburt's Avatar
dlf3yburt
Default HELP
Hi can you help me
i have a fiesta rs turbo and tonite when out in it it has started to run on 3 and has blown the oil cap off and smoking bad
do you think it could be the head gaskit or a value??
cheers
Old Sep 15, 2011 | 11:06 PM
pyromaniac_yeti's Avatar
pyromaniac_yeti
I dont know about RS turbo's, but if its popped the oil cap off then there is a shitload of pressure there shouldnt be in the bottom end.
Either you've got severe ring/piston damage - or the rings are on their way, and the crankcase breathers blocked.
Whatever you do dont run it, cause you'll chuck metal filings and fragments up round the head & probbably turbo too and completely f*ck it. I'd be inclined to get a compression tester on it, they're about £20 for the cheapo ones, see if it shows you're massively down on one cylinder. Then depending on how bad pull the head and have a look see.
