Pulsar GtiR Clutch issues???
Just bought my mates Pulsar off him thats lay in his drive for the last 3 year deteriorating. its only done about 300 miles in the last 4 years when it had a brand new clutch and transferbox fitted at Falkland Performance.
The car was last driven in july but just fired up and taken round the block to blow the cobwebs away, i collected the car yesterday and the clutch pedal was on the floor so towed it to the garage and bled the clutch with no luck of a pedal. i then flushed the fluid out and put fresh stuff in as it was black then tried again. Nothing!
After looking at the bigger picture noticed that the slave cylinder was fully extended. It appears to be stuck but wont go into gear when the car is running?
I know jack about Pulsars and im just wondering if anyone can give me pointers on what it could be? All i havent tried is to bump start it in gear to see if it will dislodge itself but the battery is on charge and al be trying this tomo after work.
All advice welcome and will be a big help if anyone can help
Cheers!
Callum.
Cheers!
Callum.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
