Silvertop Zetec guess the engine part!!
What is the thingy in the red circle.. I have the engine to go in a Sierra but dont know what to do about this bit?
Remove it and blank it off??
YES I KNOW I CANT SPELL
Thanks guys. Been painting engine bits before installing it in the car, and figured if I dont need this Im not going to waste my time on it! ... another weight saving here then
Well spotted! It is Sierra 1.8 CVH sump. They dont fit straight on, needs oil pickup pipe (the CVH one) modifying and the bolt holes on the sump drilling out. Its on now though
People have also started charging a premium on CVH parts now they know about this.
Wouldn't that be the same result with escort zetec aluminium sump? What was your aim? weight?
Front wheel drive Zetec sumps have the bowl at the front and are no good on most Rear wheel drive applications. The CVH sump obviously already comes from a Sierra and has the bowl at the rear where it is supposed to be.
I got a whole CVH engine for £40, broke it for the parts I needed and weighed the rest in so cheap too!
JoeyBoyden
04-01-2024 02:36 PM
Zoggon
10-08-2015 10:39 AM
