t34 help
hi guys,what actuator do you use with a t34.48,its on a 4x4 saph,i dont mean -31 or -34 i mean is it an escort cossie one or is there one specifically for the t34,thanks john.
When I change from a T3 to a T34 on my cossie 4x4 I found that the shaft of the -34 actuator I used on the T3 was a bit to long to fit on the T34. So I cut of half an inch of the shaft so I could adjust it the right way. Hope this helps.
Russ Payne
Sep 25, 2015 08:29 PM
