View Full Version : Technical help Q & A
- 2.0 dohc estate/24v v6 scorpio cossie engine swap?
- cosworth brake upgrade
- S1 cutting out
- Escort SI 1997 alarm
- what rack is this?
- 2.0 cams into 1.8 zetec
- which 1?????????????
- Air Con Problem
- stud and nut kit
- cossie head bolts
- Sierra Cosworth 4x4 Alternator Wiring
- Yo Techi's TIME TO SHOW OFF
- Changing the rocker cover gasket........Esc cos
- erst fuel pump relay
- fuel pressur
- trust inlet manifold for zetec in a mk4??????????????
- ecu colour codes
- 351 Cleveland
- problem cutting out.
- zvh spark
- S1 Rear disc brakes
- petrol gauge
- Electrical problem S2
- help cos electrical problems
- Parts Interchange (all fords)
- Torque settings for S2 RST head please, URGENT
- bleeding cooling system 2wd saff?
- Cossie ABS, what to check/test ???
- Snooper?
- Dash lights cos ?!?
- 4x4 Saph front propshaft - easy to replace?
- Noisy Cossie Tappets on start up...
- engine with air injectors and boost problem
- Fiesta St150 Problems
- greys
- escort mk6 electric windows and stuff not working
- Optimax or Unleaded
- Help me small end knocking noise
- noisy hydraulics
- compression pressure for s2
- Esc Cos Wheels n Tyres on Saph
- Idle Problem
- whirring noise
- help!! why is my car using oil?
- Throttle body sizes for 2.0 zetec
- MK3/4 Escort Rear disc conversions......
- zetec mk4 alternator and power steering, read this
- turbo fitting
- escos heater unit
- escos heater unit
- A quick 'un about zetecs and sierra boxes.
- Cosworth 4x4 Idle Air Control Valve problem
- hybrid turbo
- ecu
- Injector question??
- pectel board v marelli board
- Running in a new Engine....???
- CPS (CrankPositionSensor)
- Zetec or CVH
- 1 man brake bleeding kits
- help needed
- cosworth wiring ???
- Mondeo problem..
- zvh compresion
- Gears?
- S1 / S2 dip sticks ? are they the same ?
- power question rst
- oil in dizzy cap
- 3 Dr Sierra - Getting Rear Quarter light out
- Rs Turbo oil
- s2 actuator trouble
- escort xr3i mk5 seats
- restrictor diameter in the oil feed on a standard 4x4 T3?
- injectors
- piston help
- Old twin cam/cosworth mongrel
- changing engines ?
- over-reving st 200
- zetec turbo info needed, yes another one
- FRST engine vs ERST Engine
- 4wd intercooler
- Universal Intercoolers?
- Cosworth clutch release bearing
- escort cossie small turbo
- Wonkey fuel gauge on escoz
- fuel pressure
- no rev counter ?
- FRST Heads & ERST Heads
- Cossie boost problem
- injectors
- Escort Cosworth Fan Speed & A/C Switch?
- oil loss on a 2wd cossie
- zetec turbo need help
- Amal Valve
- Can i????
- fiesta clutch
- yb engine tuning question
- steering rack question
- non starter
- car stalls
- ecu diagnostics trouble codes zetec 1.8
- Cabby Power Hood
- URGENT help needed:- galaxy emissions keep failing
- Cosworth to fiesta
- Zetec16v into mk2 fiesta
- Fezzi T riveshafts please help
- 4 Speed gearbox, Gearlever floppy
- rs turbo driveshafts
- Oil Leak on 2WD from SOMEWHERE????
- orion 1.8 105ps to 130ps
- Why does my steering wheel shakes
- What size speakers do focus's have?
- cams, whats the best?
- XR3i 130 conversion using orion si parts?
- Bluefin on a Cougar V6
- escort turbo advice or maybe not?
- question about turbos
- 4 PSI....plz help lads
- Engine is Fooked
- erst clutch probs
- mondeo v6 water problems
- Help
- turbo fitting
- Snapped a valve in my 2.1 pinto. Westfield 7. with PICS!
- ABS on esrt on or off?
- weber twin 50's
- Samco Hoses
- getting very hot
- FAO wiring experts re: CPS wiring
- morrettes wiring ( erst )
- engine is pinking! any ideas
- INTERCOOLER SPRAY WATER BOTTLE
- Minimum pinto head height?
- 2WD HEADER TANK/CAP
- 4x4 cos lose power back fire
- Engine Question . .
- Alloy question....any1 help me out?
- cossie fuel pressure question?
- compression pressure?
- 2L zetec blocks
- some advice on s2 300 hp engine
- over fueling.............
- Oil Pressure Switch on a 2WD Saph.
- fuel system on an efi turbo
- Turbocharging my XR3 CARB...can it be done?
- ARP head bolts
- escort turbo management
- serious zetec power
- Fuel Pump On My S2 RST Wont Switch Off
- Idle speed
- Help needed please !
- cossie Bailey oil breather
- Turbo timer!!! 4X4 saff
- ERST dieing after start up
- Loss of power
- bleeding brakes
- non starting sierra 2wd after running out of fuel
- 3 door front bodykit arches????
- Inertia switch Locations
- zvh info needed
- tyres
- LIFT V DURATION
- valve guides
- what turbo
- over boostin
- warm engine losing all power
- help plz
- S1 engine knocking.
- Esc cos front diff
- seats
- noisey tappets/cam
- rs500 gearbox help
- releasing speedo cable Sierra mk1
- st 170 brake conversion
- FRST FAN PROBLEM
- fitting mondoe v6 brakes to my ka!!!!!!!!!!!!!!!
- Bleeding ABS pump?
- 2WD FAN SWITCHING ??? quickie
- 3BAR MAP SENSOR TESTING???
- actuators
- Focus speedo cuts out, then car cuts out.
- cold start up
- help/advice needed please!!,Turbo sorted now
- mapping your own chip
- Whisking noise from exhaust ?
- Stage one boost setting
- s2 tst wont rev about 5500 , sounds like misfire???
- Puma conversion
- Heavy power steering
- Flamer Kit
- rev Counter only showing half revs it should
- s2 fuel prob
- xr2i wheres the fuel pump
- why wont my s2 start!?!
- Smokin Cossie (there's a new one)
- engine blown
- Torque settings
- boost gauge
- ESC COS WON'T START!!
- metalic clunking ????
- throttle positioning sensor
- blowing exhaust
- pinto rattle help
- stalls on cold start
- HELP !!!!!!!!! car dead
- best zorst valves for running ALS
- 1.6 Bored to 1.9 Carb to Turbo Conversion.
- Ignition amplifier - any equiv?
- rs 500 help
- help!! Rs2000 questions
- Chargecoolers
- fiesta suspension...
- 2WD Cossie Front calipers onto S1 Turbo?
- exhausts
- idle problem
- Zetec Turbo
- s2 turbo engine to mk5 escort??????????
- Heater and wipers pack in 1988 escort cabby help!!!!
- FRST oil?
- cold start
- diy MegaSquirt ECU's
- timing up a ZVH lump
- ford f150 cambelt
- t3 sharft
- 2 LITRE ZVH HEAD GASKET
- idle speed help
- My cars having a funny turn!!!
- Breather cleaning on my cos ?
- ZVH
- mk v van--rst engine
- cossie water drinker
- ford ka engine conversion
- zetec piston pertrusion
- T3 turbo differences
- does any one know how to up the rev counter output
- boost problem with my saff
- ford Keycode Help!!
- internal petrol tank
- Boost Prob on me S2!!!
- Best oil for a modded but evryday use RST Please
- Turbo problems !!!!!
- [b]PROJECT RS 1800[/b]
- rs 2000 fan dont work
- fusion oil breather 4 pipe
- why does this get so HOT
- engine management system
- Ford spark plugs..........
- Radiator fan blowing fuses?
- Gearbox terminology?
- Dump valve, 4x4 saff
