cosworth wiring ???
Old Jul 19, 2005 | 04:39 PM
Paddy rst's Avatar
Paddy rst
Default cosworth wiring ???
when using a cosworth L8 ecu with a 2wd eng loom and a 4wd tps do the outer wires for the tps sensor have to be swapped to make it work correctly, also is there anything else that may have to be swapped/connected differently??
any info much appreciated,
cheers Paddy..
Old Jul 20, 2005 | 06:39 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yes they do. that's mostly all, but if you have an ecu from a green top, it may be expecting a lambda sensor input, and knock sensor. it will run without though.
Old Jul 21, 2005 | 02:30 PM
Paddy rst's Avatar
Paddy rst
cheers for the info m8
jdsjojo
Aug 26, 2015 10:09 PM
Aug 14, 2015 07:29 AM
jdsjojo
Aug 1, 2015 08:50 PM
