ecu diagnostics trouble codes zetec 1.8
ive just used a scanner on my orion. it came up with a code said sumting bout cylinder identification open circuit. (cid) anyone no wot it means as i dont have manual with trouble codes in help will b greatly appreciated
Can you post the code number? CID is the camshaft sensor for identifiying when cylinder #1 is at TDC. Open circuit usually means a duff sensor, disconnected sensor or failed part of the circuitry in the ecu that is associated ith the sensor.
JK12
33
26-04-2021 12:09 PM
TPM961
15-01-2018 10:50 AM
