Old twin cam/cosworth mongrel
Old 17-07-2005 | 05:34 PM
inyerface's Avatar
inyerface
Default Old twin cam/cosworth mongrel
I've been told that a cosworth head will fit on my twin-cam block so I turn to the forum to settle this argument.
When I took a look at a cos motor, the first thing I noticed was that the injection and exhaust manifolds are the other way round to mine and the main difference is mine has chain-driven-cams instead of a belt. So as an engineer and i've built a few engines (bikes & cars) I would like to know how on earth this transplant is supposed to work???
The plan is to either do this surgery to the motor or a complete swap of engine and running gear from a c-reg 2.8i 4X4 sierra i've got lined up.
Has anybody got any answers or comments please?
Old 17-07-2005 | 10:33 PM
richm's Avatar
richm
no - The I4 twincam block is quite different as you have found
Old 20-07-2005 | 06:00 PM
inyerface's Avatar
inyerface
Thanks for that richm, cause I realy want to go in the V6 4X4 translant option to be honest mainly because of the NOISE . If it gets finished I'll let you know
01-11-2015 07:53 PM
sridgett
01-10-2015 08:30 PM
XR4
Ford XR Range
01-10-2015 01:46 PM
Steve Escos
01-10-2015 07:57 AM
stevecfrst1
30-09-2015 06:18 AM
