PDA
View Full Version : Technical help Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114
  1. mk5 escort eletrical problems
  2. orion 1.6 efi exhaust
  3. YB head gasket, whats up with the hole? :)
  4. Arc welding aluminium
  5. s1 no spark
  6. mk5 zetec to rs turbo (mfi)
  7. cossie not sparking
  8. rear tyres
  9. escos fans wont switch off
  10. cossie manifold
  11. s1 over heating
  12. cossie stem seals
  13. 1.8 zetec running on 2.0 zetec ECU
  14. escos flywheel tightening torque
  15. fiesta 1.2 16 valve engine fitting
  16. will this stop the fuel pump ..
  17. Heavy smoke problem?
  18. Escos pump issue
  19. engine fitter and tuner
  20. engine trouble with rs 2000 16v
  21. bumpers sapphire
  22. s2 no brakes !
  23. will they fit?
  24. Cosworth Not running right
  25. starter not turning
  26. anodising intercooler
  27. Cosworth no spark
  28. Alternative to the RS Motorsport filler cap???
  29. Std Stat rating
  30. ST170 engine Tuning?
  31. compbrakes!!
  32. cosworth swirl pot
  33. clutch arm for mk3 and 3.5 fiestas
  34. rebore or not
  35. fiesta turbo shockers fit escort rs?
  36. cossie rims....
  37. S1 Engine
  38. fiesta mk6 clutch pedal ?
  39. just built
  40. EFI Conversion
  41. 1.8 zetec engine rev's
  42. Cosworth 4x4 stg1
  43. Problems with a 2ltr auto Capri, Help really appreciated
  44. Escort Mk5 Rs 2000
  45. Sierra Brake question....
  46. intermittent missfire when tach is connected
  47. what would it make
  48. help needed 3 bar map sensor
  49. will an rst charge carrier pipe fit??
  50. wat grade oil to put in my s2 rs turbo
  51. BD8 cams
  52. 2.0 ZVH into a mk4 fezza
  53. Xr3i misfire-hydraulic cam followers?
  54. oil light comes on wen car idles and flickers any one have any ideas ?
  55. ST220 brakes for a Mk6 escort Gti?
  56. fiesta tdci black smoking
  57. wideband o2
  58. beige injectors
  59. Cossie Rocker Gasket Oil Leak
  60. Fiesta RS1800 Cutting Out
  61. zetec auto focus help needed
  62. zetec turbo injectors
  63. compression ratio
  64. ST170 engine with vauxhall F28 gearbox
  65. is a t3 turbo ok for my s2 rs turbo????
  66. ftting a new turbo ?
  67. escort
  68. Clonking escort
  69. which cam??
  70. st170 light throttle hesitation
  71. mk4 escort stub axle
  72. only just gttin 1 psi boost
  73. quick way of changing driveshaft boot
  74. escort cosworth seats
  75. Cam Setup
  76. Black top zetec where silvertop was
  77. only just gttin 1 psi boost
  78. lack of boost
  79. dowels for headbolts
  80. Cossie - Red Valve Cover - Leaded or Unleaded ?
  81. washers stopped working
  82. Fast road cams
  83. ford bantam 2oo2 1.8td south african
  84. oil cooler
  85. ## need help for a turbo ###
  86. Another CV Joint Gone
  87. **FRST problem**
  88. fiesta cradle same as mk4?
  89. Cosworth coolant system pressure?? HELP!!
  90. door wiring saph cossy
  91. Baffelled sump help please
  92. incredable offer
  93. changing crank shaft oil seal
  94. quiet exhaust
  95. good oil?
  96. denso ik31 plugs
  97. Chassis Number
  98. Escort cossie ecu and fuel pump relays
  99. 4x4 Saphire - Radiator fans don't shoot...
  100. New MTX75 popping out of 5th gear!!
  101. Escort van immobiliser help pleasee :)
  102. Mondeo PATS
  103. stack dash wiring loom diagram
  104. flywheel refacing question
  105. toe settings mm to minutes/degrees?
  106. RST Running issues when warm
  107. Gaz coilover settings
  108. shims for adjusting toe on rear size
  109. ERST Brake lines
  110. Help me Please !!!!
  111. Turbo running problems when warm
  112. cosworth turbo to downpipe
  113. Any making sierra 4X4 bonnet vents?
  114. starting problems
  115. Saff 4x4 Transfer Box....
  116. Oil coming out of exhaust manifold?
  117. need some help with my wife's sierra cosworth rep
  118. Looking for an exhaust manifold gasket
  119. mfi xr3i fuel pump relay problem.help plz
  120. early mk3 escort not sitting right
  121. Clifford problem
  122. Sparco Bucket Seat Cover
  123. clifford alarm wireing
  124. Re-ringing a cvh
  125. ka heater matrx
  126. Battery light comes on when ignition turned off...
  127. how do i no what turbo iv got?
  128. Can't find Bodywork: Rear Panel Escort Mk3 Cabrio
  129. clutch cable difference!!
  130. RS xorst system
  131. splutter
  132. 4x4 cosworth help
  133. si upgrade few nags
  134. ford focus tddi deisel pump
  135. Roll over bar for a P100?
  136. What parts are these??
  137. Metering Unit help
  138. Cossie wont run clean - two/three cylinders PLEASE HELP
  139. xr4x4 pulsating brakes
  140. Antifreeze compatibility S2 Turbo
  141. air charge temp gauge problem!
  142. Zetec Questions
  143. escort cosworth fuel pump into escort efi tank
  144. Thread Size Temp Sender
  145. Electric Window upgrade
  146. 80spec Escort MFI turbo conversion help
  147. numberplate
  148. overheating scorpio
  149. Focus TDDI Problem
  150. I.D Of Rad Top Hose ERST
  151. Headgasket Problem
  152. Zetec Turbo Tubular manifold position
  153. s1 rst temp gauge problem!!
  154. Air injectors to external wastegate
  155. turbo zetec
  156. burton fast road cams
  157. Escort Zetec Water Pump Vanes
  158. exhaust manifold for zetec to fit cvh system help
  159. focus diesel slow at pulling away
  160. mk4 escort efi fuel fueling problem...
  161. rs2000 cv joint fit rs turbo?
  162. dump valve need help asap plz
  163. help please compression ratio for a 1.8zvh???
  164. Back pressure in the oil and now a juddery break pedal!
  165. will this fit
  166. more bhp :)
  167. zvh not running right
  168. 4x4 t3 turbo
  169. Fin code for oil seal
  170. s2 escort rs turbo - turbo manifold probs
  171. lecky widows and mirrors
  172. tempature clock
  173. Which engine oil is best???
  174. rs turbo brake master cylinder what pipe go where
  175. Do I need an uprated fuel pump
  176. MTX Final Drive change
  177. Ford 2007 & 2040 wiring?
  178. cosworth inlet manifold plastic connectors
  179. idle rpm
  180. YB engine bearing replacement
  181. YB piston / bore clearance
  182. 4x4 cosworth breather problem
  183. Ignition amplifier
  184. mk2 fiesta cradle fit a s2 rs turbo?
  185. cossie stinks of fuel?????
  186. 4x4 saph oil plug
  187. Revs not dropping
  188. Car a bit jumpy
  189. Which starter motor do I need ?
  190. Will Escort Rs Turbo Clutch Fit MTX75 Gearbox
  191. good garage for MOT NW London area?
  192. Best Plugs For a Cosworth 4x4
  193. mk6 1.8 td tuning help please??
  194. cossie 3 bar map censer
  195. st170 run probs.
  196. help no power
  197. s2 rs turbo howling when coming on to boost?
  198. central locking keeps locking?
  199. focus brake problem
  200. I have a few problems
  201. Mk3 fiesta replacement panels
  202. how do u use the zetec camshaft timing locking kit?
  203. bottom end rebuild
  204. 1990 Sapphire Cosworth - PAS, alternator, window surround bubbling issues etc
  205. escort dash bord
  206. help help bloody help
  207. Rad Hose Split By Power Steering Pulley
  208. Ford Escort ignition problem
  209. rs2000 drive-shafts fit my rs turbo??
  210. Gearbox fault
  211. ARP BOLTS
  212. 1800 zetec conversion
  213. Aeroquip
  214. 044 pump and filter fitting help.....
  215. series 2 rs not boosting
  216. 1.6 zetec on 2.0 b/e ?
  217. Bellhousings..
  218. handbrake sticks
  219. Leaks on 3door PAS pipes!
  220. I have just recieved the wrong fuel tank, s1 rs turbo, so which fuel tank have i got
  221. Tech Books.
  222. FAO people with cvh fiesta's
  223. focus TDDi help
  224. endura de 70ps to 90ps how do i go about it
  225. where is the knock sensor rst
  226. cosworth starting problem
  227. 'Y' Plate Mondeo 2.5 V6 Cutting Out!?!
  228. YB getting hot!
  229. Escort 16v Si Acceleration!
  230. Focus TDCI losing power
  231. front brake pads now got engine mang light on
  232. cosworth intercooler
  233. Escort turbo and Fiesta Turbo Brakes
  234. Working out compression ratio
  235. Cossie valve seat
  236. '93Granada Scorpio Cossy Power Steering Rack...
  237. firin order on 3i cabby
  238. undersealing in essex or london?
  239. cossie t5 5th gear needed...
  240. bore liners for CVH turbo??
  241. notchy netrual
  242. pinto head gasket
  243. pinto EFI trouble
  244. dam fiesta rs turbo
  245. ST170 induction
  246. Fuel Pump Pressure from mfi to efi
  247. cosworth missfire
  248. ECU problem with conversion
  249. p8,injectors and coil packs fitting advice please
  250. oil pressure and volt gauges
