Leaks on 3door PAS pipes!
Iv got a small leak on my pas pipe were it goes in to the pump , it looks like it comeing from the pipe it's self, iv sealed it about 5times
but still a little damp, anybody had the same problem
but still a little damp, anybody had the same problemI've found that life I needed.. It's HERE!!
i cut mine & welded -6 fittings on & fitted an adaptor into the pump & fitted goodridge hoses in. also fitted a small cooler where the long metal pipe ran under the pass side inner guard
much neater job
much neater job
