Rad Hose Split By Power Steering Pulley
Old Jun 4, 2009 | 09:29 PM
Olivera's Avatar
Olivera
Default Rad Hose Split By Power Steering Pulley
Hi all,
On a trackday recently the radiator hose was split by the power steering pulley below, as there is only about a 1-2 inch gap in between. I guess the engine moving about on track caused this to happen.
Now, I have a new Roose hose but have noticed it is exactly the same shape and still sits very close to the power steering pulley. Any ideas how I can get more clearance between the hose and the pulley? The radiator is bolted onto the chassis and I'm not sure it can move anywhere? I should note that I'm running a new airtech rad and cooler, so perhaps this has moved things slightly vs standard?
Help would be appreciated!
Old Jun 5, 2009 | 09:24 AM
I'm also running airtech stuff, no problems here.
When I was looking at cozmeister's car last weekend, I did notice that his top hose had a bend in it, and that put it a lot closer to the pulley, he had very little clearance as well.
The bend I am talking about is about halfway along, it swoops downwards, I fitted a new genuine ford top hose a few years back, and it is different in that it is totally straight between the actual end bits, that turn towards rad and stat.
Maybe ford changed the shape due to this, as there is shed loads of clearance on mine.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
pabloXR
Sep 21, 2015 12:42 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
hopper350
Sep 4, 2015 12:53 AM
