MTX Final Drive change
Old Jun 8, 2009 | 07:10 PM
Rick's Avatar
Rick
Default MTX Final Drive change
What's involved in changing the crown wheel and pinion? How much of the box needs to be stripped? Only gearbox i've ever opened is a Mini one about 10 years ago...
Rick.
Old Jun 8, 2009 | 11:56 PM
pdfbt40's Avatar
pdfbt40
Complete disassembly and rebuild as the output pinion is integral with the second shaft IIRC. That means the end float of the shaft has to be measured and set by shims.
Martin
rex647
Mar 6, 2022 06:20 AM
xrmalin
Sep 13, 2015 06:52 PM
gingeRS
Sep 4, 2015 06:29 PM
