Will Escort Rs Turbo Clutch Fit MTX75 Gearbox
I am looking to fit an mtx75 gearbox to my zt van which has an ib5 gearbox, Will my clutch fit the mtx75 box?
Si
Si
YES I KNOW I CANT SPELL
your going to have problems getting a clutch for it that will take the power you want .have you thought about getting a focus rs box they have a diff as standard and a short shift gear stick and hydraulic clutch witch is really nice. and you dont need a paddle the organic is good for well over 300hp
Would an rs2000 clutch fit with the fiesta rs turbo flywheel?
Would this be any good?
http://cgi.ebay.co.uk/PERFORMANCE-PA...|293:1|294:200
Si
Si
Si
Si
Si
Si
Si
I'm surprised no-body's mentioned that using 240mm clutch meant for a FRS doesn't fit in a cable release MTX. Although the 2.0l Zetec flywheel has been the same since '92 and will take a 240mm clutch, the normal road clutch is 228mm.
ZF Sachs do a 240mm clutch for the 2.0 Zetec/ST225 in organic and cerametal/paddle. Seem to remember had quite good ratings. Also the cover was pressed steel rather than the bulky alloy of AP, though that might have been a generic illustration.
Martin
Martin
matman
09-09-2015 05:45 PM
wheelwizardrefurbs
04-08-2015 06:23 PM
hazbaz1984
Ford Focus (All Models)
30-07-2015 05:15 PM
