overheating scorpio
Old Jun 12, 2009 | 08:14 AM
lleewar's Avatar
lleewar
Default overheating scorpio
Hi Just bought my 95 scorppio ultima and it is overheating and the fans are not cutting in. Help me save my head gasket. Thanks
Old Jun 12, 2009 | 09:03 AM
Bridge the fan switch if fitted, may be ecu controlled ?
If bridging the switch worsk the fans, repalce switch, if there isn't a fan switch, disconnect ecu plug at coolant temp sensor, ecu sensor not gauge sensor, and it should bring the fans on as a default.
Old Jun 26, 2009 | 09:39 AM
lleewar's Avatar
lleewar
Thanks Tabatha. All's well now thanks to your great advice Cheers Lee
Old Jun 26, 2009 | 09:48 AM
No probs, glad to see another old ford kept alive.
Ian1964
12
Jan 26, 2021 11:57 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Tony W
Sep 9, 2015 12:08 PM
markk
18
Aug 17, 2015 05:19 AM
Lil Abner
May 4, 2005 08:29 PM
