zvh not running right
Old 09-06-2009 | 10:17 PM
sully's Avatar
sully
Default zvh not running right
hi iam new to this just got escort cabby rs turbo zvh it strugels to turn over just put a new battry on and still thes same it seems like the battrys dead its got a justaby pulley on if the timeing is out will it strugel to start and its running 1 bar ov boost with a standit intercooler on and when iam driveing and hit boost in 2 3 and 4 it missfires plz help
Old 10-06-2009 | 08:36 AM
Ignition too far advanced can make it do this, ie turn over slowly, but there are other causes, duff starter for example.
Old 10-06-2009 | 05:35 PM
sully's Avatar
sully
timeing set but still strugls to start it will turn over once then stops like the battrys dead could this be the starter morto can eney one help
Old 10-06-2009 | 06:31 PM
mikey_clough's Avatar
mikey_clough
check the connections at starter and battery for corrosion, or like tabetha said, duff starter!
Old 10-06-2009 | 06:40 PM
Could easily be the starter, especially if worn.
Old 10-06-2009 | 06:45 PM
sully's Avatar
sully
thanks lads ill get a new starter tomoz
Old 11-06-2009 | 07:22 PM
sully's Avatar
sully
got a new starter today stating fine but got a bad miss fire when iam in boost
Old 12-06-2009 | 09:08 AM
Check the plug gaps first, then for any air leaks.
Old 14-06-2009 | 05:19 PM
sully's Avatar
sully
starts ok when its cold but will not when its hot
TPM961
15-01-2018 10:50 AM
`spotty
25-09-2015 11:41 PM
dombanks
21-09-2015 08:38 PM
tib2220
14-09-2015 12:33 PM
Eigdoog
13-09-2015 05:46 AM
Quick Reply: zvh not running right
