front brake pads now got engine mang light on
hi glad to be a new member but can anyone help please was out sunday brake light came on on dash board 2 miles down road then the engine management light came on replaced front pads as were low but lights are still on do i have to take to ford garage to get reset or am i missing something
The older cars warned you when the pads were low but thought this was a thing of the past and I am not convinced thats whats causing your problem.
If u disconnect the battery for 10 mins this normally clears the KAM and extinguish the light. Does the car run as normal as I would have thought it will be in LOS?
Martin
Martin
