burton fast road cams
Old Jun 10, 2009 | 09:16 PM
proboscus's Avatar
proboscus
Default burton fast road cams
i have 2 good 4wd standard cams that im thinking of sending to burton for reprofiling as fast road cams even though the followers are ok no tapping at all would it be advisable to change them too.also would the power gain be worth the hassle and expense?any comments please
Old Jun 11, 2009 | 10:33 AM
If the tappets are ok just take them apart and clean them out.
Hard to say whether it would be "worth" it with fast road cams, bearing in mind you can't go too mental due to presumably not having pocketed pistons ?
Personally I would just do the exhaust to BD15 profile, a lot change the tappets as a lot easier to do this when changing the cams than a seperate job on it's own later on.
Nov 1, 2015 06:53 PM
